Results 1 to 8 of 8
Thread: water leak into spare tyre well
    HSV.006's Avatar
    HSV.006 is offline Apprentice Mechanic
    vq statesman. CSV strada 5000i.
    Sep 2008
    adelaide
    Default water leak into spare tyre well
    ok its happened to 1 of my vp's and my vq so im guessing it could be a common problem,
    water is leaking from somewhere into the spare tyre well. i think it maybe the 2 black air vents or whatever they are that you can see when the spare wheel is out and its going into the rear bumper and through that, i havnt had much time to have a good look or try to fix it so if anyone else has had this problem please let me know,
    cheers!
    TVR-190's Avatar
    TVR-190 is offline SkyFall
    WK Statesman LS1
    Jun 2008
    Sutherland Shire N.S.W
    its very common actually. Mine had it happening but drained out because it had rusted through.
    Check the boot seals and rear quarter windows, also the rear tails lights.
    Best way to check is take everything out, stick the hose on the roof and let it run as a dribble for about 10 minutes, im betting its the seals on the brake lights
    The Black Beauty
    Philthy's Avatar
    Philthy is offline That dent guy
    VS Berlina, XC AMS Project
    Aug 2005
    Have a look here - How To Fix A VN-VS Boot Water Leak
    Also check the taillights. One side on mine was the window, the other side was the taillight
    VT Berlina Wags
    Aug 2009
    Bellarine Peninsula
    Quater window.....my old vs did the same thing and windscreens obrien charged me $130 to refit and reseal the window onsite....no more leaks.A mate did have a leak through his tailight in a vn as Philthy stated.Check both and get it done before it rusts out.
    CAR ,Y U NO FIX YOURSELF
    Jan 2007
    rear quarter windows. Remove plastic trim on the inside of car remove the 5 or so screws holding the window in push it out clean of the old crap and mud get some sikaflex and re seal them should be good for another 10 years.
    Could also be the rear tail lights water leaking in threw them so reseal them also.
    VQ Stato & Evo VII.
    May 2006
    Melbourne, North of.
    It was the tail lights in my vq that were allowing water to get into the boot, both sides. Luckily I had another spare new set of tail lights sitting here so just swapped them over and haven't had a problem since.
    HSV.006's Avatar
    Sep 2008
    adelaide
    cheers for the replies. Will have to suss a few things out over the weekend and see if i can sort it out.!
    millaz88's Avatar
    millaz88 is offline wishin me v6 was blown :)
    vn commodore
    Sep 2009
    gippsland
    my tail lights were leaking into my boot and filling with water i just drilled a small hole in the bottom of the light so it could drain out as i cant be assed payin $70 each for new ones atm
  1. Behind spare tyre -- need help
    By blindworld1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-02-2009, 09:48 PM
  2. Spare tyre?
    By LightningVP in forum General
    Last Post: 21-11-2008, 10:33 PM
  3. Crewman spare tyre handle
    By maginoodle in forum VY Holden Commodore (2002 - 2004)
    Last Post: 19-03-2007, 06:39 AM
  4. Spare Tyre
    By Sick Blue VL in forum Car Audio
    Last Post: 27-08-2005, 08:34 PM
  5. Spare Tyre
    By Sick Blue VL in forum VL Holden Commodore (1986 - 1988)
    Last Post: 25-08-2005, 06:49 PM
