Results 1 to 7 of 7
Thread: vs dash cluster fit vn ?
    Jul 2008
    Default vs dash cluster fit vn ?
    hey just wondering if the vs dash clusters fit into vn commodores?
    do the plugs line up on the back
    and is the wiring the same so will everything work??
    anyone tryed doing this yet
    cheers
    mischa's Avatar
    mischa is offline <- 245rwkw Holden V8
    VN V6 T5 - 355 VN GRP A REP T56
    Jun 2005
    Ashbury, NSW
    If your just swaping them stright over it wont work and it will go up in smoke. You can change the backing of it so it will fit tho, i had lvl2 VS in my VN before the lvl3.
    Quote Originally Posted by keza87 View Post
    Really who wouldn't want to give Jack a good smack in the back of the head.
    The Daily VN T5V6
    355 VN GRP A REP
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Trip computer is all wrong too. Low fuel alarm goes off when the over speed is triggered and when you get low fuel the speed warning has fun.
    Not worth the effort.
    and 3 Dangerous non ABS VN's
    VN Exec
    Jan 2010
    88GreenVN's Avatar
    Jun 2006
    Quote Originally Posted by VNwithFE2 View Post
    Swap fuel alarm n speed alarm over or just in ur head change beep codes
    The level 3 clusters are fail on several fronts. The wires are different, voltage regulators, PCB, trip computer. Only items to be changed are the cluster case and the set of gauges.
    For level 2 it's the same - case and gauges can swap between VN and VS. Just not the cluster PCB or voltage regulator.
    lemusa's Avatar
    lemusa is offline Unmotivated Enthusiast
    VN Exec V6 Manual
    Jan 2010
    Christchurch, NZ
    Much easier gettin one from a calais. If your lucky (alot of series 1 vn's) youl have the trip computer plug there as well, mine was tucked up behind the dash covered in gooey stuff.
    Unless you mean swapping a level 3 vn for a level 3 vs. Which I believe just results in smoke
    88GreenVN's Avatar
    Jun 2006
    Quote Originally Posted by lemusa View Post
    I think alot of the NZ VN's went with the Calais loom in them and L1 or L2 clusters.
  1. vz-ve dash cluster??
    By nathan549 in forum General
    Last Post: 25-10-2010, 12:04 AM
  2. VY SS Dash Cluster
    By buzurk in forum Parts And Other Items For Sale
    Last Post: 12-02-2008, 12:27 AM
  3. Dash cluster
    By glowworm in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-01-2008, 06:12 PM
  4. Swapping VR L2 dash cluster with VS Stato L3 Cluster
    By wheredoesthisgo in forum Electrical Wiring / Questions
    Last Post: 07-04-2007, 03:28 PM
  5. Replace VN dash cluster with VX dash cluster
    By Xalies in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-02-2005, 06:55 PM
