Results 1 to 15 of 15
Thread: 3.8 V6 into CF Bedford Van
    CF Bedford
    Oct 2009
    Default 3.8 V6 into CF Bedford Van
    Hi
    I've joined this forum to ask a couple of questions if I may.
    I am in the process of midmounting a 3.8 V6 out of a VN into my CF Bedford van. The engine is coming from a VN donor car I have purchased. I have acquired a 'dummy' engine and trans to help me with the fitting before I remove the engine from the car. This is so i can remove the heads and covers and weld and grind around it without worrying about damaging the good engine.
    Now the donor engine I have noticed that the dipstick comes out of the drivers side of the sump whereas the dummy engine has the dipstick in the front of the sump over towards the passenger side. I would prefer the dipstick to be front mounted so would like to swap the sumps over. Is there any issue with this like the oil pickup in a different place because of different baffling etc or no issue at all?
    My second question relates to extractors. Do the different models of extractors extend out from the exhaust ports the same distance as the standard cast exhaust manifold or extend a bit furthur? Do you know if some models sit closer to the block than others or do they all pretty much follow the same route as the original exhaust system?
    Many thanks for your time.
    CF Bedford
    Oct 2009
    Oh, and another question. Looking under the car I can't see the transmission selector without getting the car up on a hoist. Which position is the selector in 'Park'? All the way forward or all the way back? Thanks.
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    sump will be a direct swap .extractors most will fit as they are tucked in pretty tight on a commodore to make them fit will just depend on the crossmember wether you can fit longtube pacemakers or if you need to stay shorty style ones.gearlever on the box is full back for park
    VS Berlina 3.8
    Dec 2008
    Quote Originally Posted by delcowizzid View Post
    Wouldn't that be first? I thought it went -
    P
    R
    N
    (D)
    D
    EDIT:
    This was the best picture I could find in "My Rides", might help.
    CF Bedford
    Oct 2009
    Thanks very much for the quick response. I've used the original VN crossmember so I imagine I could use either type of extractors.
    Pub247's Avatar
    Pub247 is offline Donating Member
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    rjk just because it all the way forward in the car doesnt mean it like that on the box remember there are linkages and stuff between the 2
    Quote Originally Posted by Smidy
    How many kw would i need to beat vin diesil to the train lines?
    Reaper's Avatar
    Reaper is offline Tells it like it is.
    E3 Senator Manual, VP SS
    Aug 2004
    Love the old beddies - great project. More pics as it progresses would be great
    Reaper
    Reapers Black VP SS
    0-60 mph = 5.39 Sec, 2.30 60'
    Quote Originally Posted by skruba View Post
    practice makes perfect dude i was (still am) my bros guinea pig,he has been tattooing for near 2 years.
    CF Bedford
    Oct 2009
    Reaper
    Thanks. Here's a couple of the external mods so far. These were back when it had a mid mounted 186.
    VS Berlina 3.8
    Dec 2008
    Quote Originally Posted by Pub247 View Post
    Ahh, check, now I get where your coming from.
    NO CAR ATM.. -.-
    Jul 2006
    VP Executive R-spec
    Jan 2005
    VP Executive R-spec
    Jan 2005
    Reaper's Avatar
    Aug 2004
    Quote Originally Posted by Rogue Trooper View Post
    ...... sigh..... I did ask I suppose. You ruined it!
    Reaper
    Reapers Black VP SS
    CF Bedford
    Oct 2009
    Wink
    Reaper
    Just as well I'm building it for me and not you then I suppose. ;-)
    Considering it was written off face-first into a large road working truck I think it came back rather well.
  15. #15
    Reaper's Avatar
    Aug 2004
    Indeed - If your happy that's all that matters. best of luck with your project.
    Reaper
    Reapers Black VP SS
