Results 1 to 3 of 3
Thread: Throw out bearing
    Jul 2008
    Default Throw out bearing
    Hey i have a bit of an issue, i did a clutch recently and my old throw out bearing was farked, it had sliped of the fork and the plastic caseing was deformned and the back of the presssure plate was ****ed because of it.
    How do i stop the bastard falling off again, as far as i can tell they just sit in there and rely on pedal pressure to keep them firmly attached to the fork so to speak.
    The only prob with this is i wasnt able to achiecve the quoted 39 mm or so from clevus to rear of bell houseing, and my pedal high isnt what its ment to be :P so there is a bit of play in there.
    And allso where does your cluch engage in a Vp V6, mines only grabbing in the last 1/4 just over half of pedal movement. I like em to grab about an inch off the floor.
    PaRaDoX's Avatar
    PaRaDoX is offline boosted!
    Forester GT, VT S Supercharged, Supra Turbo
    Apr 2005
    Melbourne, Victoria
    i've only even pulled apart my supra 5 speed but it should be similar,
    the throw out bearing should be FIRM against the housing it sits on, if not then you need to replace the housing as its worn or the bearing is wrong. the bearing should be sandwiched against the end of the housing (which the clutch fork connects to) and the pressure plate fins,
    i've got a hydraulic system but you should be able to adjust the cable, maybe at the pedal.
    94 vr 5sp, 04 vz wagon,82 vh efi wagon,88 vn 5sp
    Nov 2003
    northside brisbane
    Just pulled mine out and there is dramas.....spigot is loose in the crank and fell out with the clutch.....fingers or the pressure plate are worn paper thin and off centre......throwout bearing is still in one piece but the cushion tabs are gone nowhere to be seen....and I put them in about 4 years ago....the throwout surface on the input shaft retainer has significant wear to one side.....wtf?
    This is my vr that I rebuilt ....CLICK HERE to see my vr on Cardomain ......if you want to check it out......Anyway make sure you rubbish a ford daily ....I am a 4DH8RZ Club lifetime member .................new members joining everyday
  1. Throw Out Bearing Issues
    By Chris E in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-05-2009, 06:58 PM
  2. Throw Out Bearing, I Think
    By vt s in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-05-2009, 07:09 PM
  3. Throw out
    By DavoVP in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-04-2009, 10:43 AM
  4. throw over canvas seat covers
    By tysonsvyss in forum General
    Last Post: 27-03-2007, 07:49 PM
  5. Anyone got a leaf spring they wanna throw away?
    By DavidPartay in forum Swap / Wanted to Buy / Trade
    Last Post: 18-10-2006, 07:55 PM
