Results 1 to 13 of 13
Thread: bit of a annoying problem
    VN commodore 3.8L
    Aug 2008
    Warilla, NSW
    Default bit of a annoying problem
    every now and then, well actually happens everytime i drive now, ill be stopped or stopping at the traffic lights or something, and the revs seem to drop and stall, its really annoying, any help with what this could be? happen to anyone else with a vn? thanks.
    vx gen111 wagon
    Jul 2009
    perth
    Dodge ram 5.9V8, 03 VW Bora, VS 5.0L
    Sep 2009
    Sunshine Coast
    Does it just drop down in revs and stall or does it rev up and down type thing before it does? If it only does it when the brake is pressed down it could be the brake booster having a leak or maybe timing
    Commydoor's Avatar
    Commydoor is offline born in the FB era
    Vr Ss Blown
    Sep 2007
    Beresfield, NSW.
    vacuum leak, dirty throttle body, crook injectors, plugs, etc etc etc, when did it have a complete service last?...
    VN commodore 3.8L
    Aug 2008
    Warilla, NSW
    its an auto, well come to think of it mate, i think they only drop when im braking, as i start braking the revs will be on about 1000, then by the time ive nearly stoped there on about 100 ahha, it gets serviced about every 3 months, last major service was over a year ago, could it be a sensor? should i take it to a mechanic, or an auto electrician?
    Commydoor's Avatar
    Vr Ss Blown
    Sep 2007
    Beresfield, NSW.
    try when you stop and the revs are down quickly take your foot off the brake and see if the revs pick back up...if it does it might be like Jaywa says and be a vacuum leak at the booster
    VN commodore 3.8L
    Aug 2008
    Warilla, NSW
    yeah naaah, once the revs are down they dont come back up, unless i put it in neutral and give it a little rev, which is how i prevent stalling haha
    Commydoor's Avatar
    Vr Ss Blown
    Sep 2007
    Beresfield, NSW.
    the ICS on the throttle body might be clogged or failed blocking off the airflow when the butterfly is closed after youve backed off
    calais_cruzin's Avatar
    calais_cruzin is offline Calais_Rattling....
    92 VP Calais 3.8
    May 2006
    Gold Coast
    Its the IAC in yo throttle body, best to take it apart n clean it, but can be done with jst throttle body cleaner.
    Mine play up eveyr 6months or so, have to rally drive at the lights, foot on brake n accel
    ________________________________________
    Ke30 Rolla'
    Oct 2009
    RAD-elaide
    Quote Originally Posted by Wadeo.. View Post
    i have this exact same problem, when im running on gas, runs fairly decent on petty, but when i brake on gas, i have to "Rally Drive" to keep it running
    VN commodore 3.8L
    Aug 2008
    Warilla, NSW
    yeah i cleaned it all with throttle body cleaner, and it seems to be fine ay!, so happy ahah
    try that vn_commonwhore!
    Tim Smtih's Avatar
    Tim Smtih is offline Sexy Man
    VXS1 Acclaim Family spec Limited Hardcore Edition
    Sep 2009
    Here.
    I seem to be experiencing a similar issue. The revs are only one hundred less then they usually were at idle, but the engine seems to be idling rough and when i hold my hand over the tail pipe it's a bit rough as well. I have changed the fuel filter, and removed and cleaned the throttle body (being cautious not to get carby cleaner into the sensors), i also changed the coil pack over to a newer one that was putting out better ohms reading. All spark plugs and leads checked, etc. I'm guessing a sensor on the way out maybe, damn i hope it's as simple as that. Any ideas?
    http://tinyurl.com/MetalisAwesome
    Only two things are infinite, the universe and human stupidity, and I'm not sure about the former.
    Albert Einstein
    Ke30 Rolla'
    Oct 2009
    RAD-elaide
    Wink
    ill do that tomorrow , ill go out a buy a can of cleaner, and try it out ! , then i can save my premium fuel, for better things
  1. Annoying Problem.
    By Torniquet in forum Car Audio
    Last Post: 02-03-2009, 10:13 PM
  2. An annoying problem
    By HoldenManDan in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-01-2007, 11:08 AM
  3. please help - annoying problem
    By =Calais v8= in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-11-2005, 08:11 PM
  4. Annoying Problem!
    By ChRiDDa in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-02-2004, 12:50 PM
  5. Annoying Problem...
    By fourstar82 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-02-2004, 05:46 PM
