Results 1 to 16 of 16
Thread: All vp owners plz help
    Vp exec
    Feb 2009
    Melbourne ;D
    Default All vp owners plz help
    Hey guys
    Now today i noticed when i was driving my brothers vs that its powersteering was so much more liter then mine
    Is it normal for a vp to have really heavy power steering or is it just my car
    feels like a dont have powersteering at all n i have fluid in it, theres no leaks or anything
    plz help
    Quote Originally Posted by Jecs View Post
    just dont do anything stupid like i did.
    when my ex left me, i lost my shit and went to the bank and got a $10 grand loan out. said to my self 'im gunna build a tuff as f**k engine and do a skid in her driveway'
    built the engine. bought the tyres. never did the skid.
    i got with her best friends instead.
    VT Berlina Wags
    Aug 2009
    Bellarine Peninsula
    Depends on how heavy but it could need a simple power steering flush,it could also need a wheel alignment and maybe it could even be the steering rack itself.If its heavy az then try the simple approach first,check your fluid colour and if its yuk and brown then flush,if it is foamy flush....pays to flush anyway every now and then.Camber wear is another issue i guess could be looked at.
    CAR ,Y U NO FIX YOURSELF
    VT Berlina Wags
    Aug 2009
    Bellarine Peninsula
    Check this site for heavy power steering threads.
    VP BT1 & BLOWN STATESMAN
    Oct 2005
    What kind of VS is your brother cars, cuz calais statesman have speed sensor on there one and they are alot lighter to turn than non sensor one
    NEVER LATE IN A 355ci
    VS Berlina 3.8
    Dec 2008
    Or it could just be that the VS is newer and your power steering is worn out.
    VQ Caprice II
    Aug 2006
    From memory the pump on VR/VS had greater pressure, which made it easier to steer.
    also VR/VS have different front suspension setup
    - different sort of wheel bearings
    - different camber/castor
    - different front wish bones and struts.
    on VN, VP, VQ - they are a bit firmer, but if it is hard when you are parking etc, then your rack will be excessively worn, but a flush will help, and it's cheaper intially to test.
    hope this helps
    Vp exec
    Feb 2009
    Melbourne ;D
    Quote Originally Posted by BT1-355 View Post
    its just a normal exec man
    Vp exec
    Feb 2009
    Melbourne ;D
    Quote Originally Posted by spirto View Post
    hope this helps
    hey
    yeah its really hard when i am parking
    so ill give it a flush n see what happens
    whats the process i have to do to flush lol
    ScoHar's Avatar
    ScoHar is offline Jizz in my pants
    02 VX Equipe V6
    Apr 2006
    CHCH, NZ
    go get a wheel alignment before your flush, you may be surprised, pretty much every 2nd hand car i've owned has had either hard or too light steering all been fixed by a simple wheel alignment, i'm not sure what part of the alignment they fix but it makes a world of difference and its not noticeable on tyre wear either.
    Gas, Ass or Grass nobody rides for free
    Quote Originally Posted by vsv8berlinawag View Post
    You tell him (coz you are right)
    VP Executive R-spec
    Jan 2005
    My VP has a fairly new rack and it's light pretty much the same as my brothers VS V8 exec with 80,000ks on it. You can't really tell any difference between them
    VS 96 Exec Wagon
    Jul 2009
    Queensland
    Wheel alignment by far dude. When I got my VP it was lose..but after I bought it new shoes.. i got a wheel alignment done.. It's hard. but not hard enuff to piss me off
    Paintball.. It's not just a Sport.. It's a lifestyle!
    Check out my VS Wagon !
    See my Re-Mixes here YouTube - Dtek5
    VQ Caprice II
    Aug 2006
    when it's really hard at slow speeds e.g. parking. means the worm drive inside it is not getting enough power steering fluid, so it is getting low pressure.
    to flush it (this is what I do)
    - you can take of the return pipe and plub into a bucket,
    - block where it attaches on the fluid bowl.
    - add new power steering / trans fluid
    - get a mate to turn the steering from left to right (obviously engine on). full lock both ways.
    - you should then see fluid rush out the return pipe that is in the bucket.
    - keep adding new fluid till you get a clean stream.
    - you can then add an additive to help.
    - reconnect return pipe.
    test if it frees up, solved, if it still plays up, you can get a wheel alignment, but most likely it's the rack.
    I don't know if there is a how to on doing the flush, so guys feel free to link us up if there is.
    ducker85's Avatar
    ducker85 is offline Calais man
    09 VE clubbie R8
    Oct 2008
    Adelaide SA
    Calais and Statemans have power steering assit so it maybe fitted to the vechical with the lighter steering
  14. Default
    my power steering used to be really soft, i had to have the pump changed for RWC, now it's pretty stiff... definitely much harder than other cars i drive (mums lantra etc). i hated it at first but now i kind of like the harder steering.
    Quote Originally Posted by zai View Post
    I am not sutpid
  15. #15
    Vp series 2
    Jun 2008
    stretch the spring in the pressure valve on the pump to crank the pressure up.
    it is meant to increase the assit when you do that.
  16. #16
    NO CAR ATM.. -.-
    Jul 2006
    mine was probably the worse powersteering ever known to man. nearly cause accidents (to myself) and never went to a shoping centre coz it felt retarded trying to park..
    well the fix for me was. fully drain the oil like the guys said, i changed my power steering pump too!
  1. All VR/VS owners
    By kopper69 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-09-2006, 05:55 AM
  2. vn-vp owners,
    By 38VNIT in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-09-2006, 08:33 PM
  3. Any XU6 Owners
    By scbh81 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 06-11-2005, 08:29 PM
