King springs im wondering what the ride height is for low and ultra low?
was told that low was same height as the FE2
Real cars don't power the front wheels, they lift them
Do a search, been covered heaps.
starting to miss the point of a fourm if you carnt ask questions
And you can ask questions the problem is there are 100's of others with the same question.
Use some initiative: http://forums.justcommodores.com.au/...&q=ride+height
ultra lows will probably drop the ride around 3 inches 60 mm, measured from centre of wheel, and wheel arch.
FE2 - about 1 & 1/2 inches or 30 mm.
King Springs also don't sag, (well that's what they say). but pedders, lowells, webb, industrials, do give a bit.
thanks
my king ultra low sits the rear about 280mm (200 being a calais) and the lowells super low sit it 240 to the calais gaurd spat so 320 to the guards if i remember correctly mate
fe2 are still available from holden.
just got the fronts, $60 each.
