Page 1 of 3 123 LastLast
Results 1 to 25 of 59
Thread: i want 2 pull 145RWKW
    vt s pack manual
    May 2009
    gawler, adelaide
    Default i want 2 pull 145RWKW
    i have a vp calais 3.8l v6. i have pacemaker extractors, 2.5inch catback and ss cold air induction. i want 145RWKW what do you guys sugest 2 get 2 that ? im already getting injectors and a comp cam is high on the list. forced induction is also an option.
    any ideas ?
    Zuicider is offline Banned
    Set of thongs
    Caribbean Stud Poker Champion!
    Dec 2005
    Stonedville
    vt s pack manual
    May 2009
    gawler, adelaide
    the 1 i want requires headers and exhaust kit. no head work
    Set of thongs
    Dec 2005
    Stonedville
    thats a small cam, oh well just et a tune after the cam, if its not too small and u should be close
    TVR-190's Avatar
    TVR-190 is offline SkyFall
    WK Statesman LS1
    Jun 2008
    Sutherland Shire N.S.W
    Should nt too hard, one of the guys on here was running 140rwkw N/A vp calais if i remember right
    The Black Beauty
    Cobez's Avatar
    Cobez is offline LS-EXUAL
    2004 S2 VY SS Ute
    Feb 2007
    Why 145rwkw specifically?
    Quote Originally Posted by wikky
    As already stated, mate you're an absolute gherkin strummer.
    Pub247's Avatar
    Pub247 is offline Donating Member
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    Quote Originally Posted by TVR-161 View Post
    i own that motor now its running a wade 992 cam but it also has ported heads and a slight increase in compression. If you were to bump the comp up some more and run a bigger cam you'd get it but i think anything close to that is decent.
    Quote Originally Posted by Smidy
    How many kw would i need to beat vin diesil to the train lines?
  8. Default
    if forced induction is an option, i'd just go and grab an sc14 and bolt that on. easy and cheap power
    The SC14 Supercharger Thread
    Quote Originally Posted by zai View Post
    I am not sutpid
    vt s pack manual
    May 2009
    gawler, adelaide
    Quote Originally Posted by Cobez View Post
    stupid reason. beat my mate who pulls 140rwkw in a vs clubsport but i like the amonut of power he has its nice its there if you want it but its not rediculusly race only purpose.
    Jun 2005
    buy the supercharger in my shed and youll be well on your way to 145rwkw
    1995 Manual HSV Clubsport
    1991 Supercharged VN Berlina
    AirStrike's Avatar
    AirStrike is offline Site Administrator
    2009 G6ET
    Jun 2003
    Quote Originally Posted by E-T-H-A-N View Post
    He'll still beat you, it will have more torque.
    wikky is offline ............
    VZ SSZ
    Mar 2008
    Here
    Wouldn't a VS Clubby make more than 140rwkw?
    Also, 2 cars that make similar rwkw on a dyno can drive very differently on the road. You've got to remember that dynos are primarily a tuning tool.
    Jun 2005
    Quote Originally Posted by wikky View Post
    not without mods no
    VZ SSZ
    Mar 2008
    Here
    Quote Originally Posted by stocky View Post
    not without mods no
    Well there you go. Thanks for that.
  15. #15
    Cobez's Avatar
    2004 S2 VY SS Ute
    Feb 2007
    Quote Originally Posted by AirStrike View Post
    Beat me to it. Torque wins the race!
  16. #16
    Vp series 2
    Jun 2008
    masive head work.
    get a real good machine shop to bore the block then sleeve it to fit chev 400 piston.
    don't for get to upgrade the oil pump mains caps and oil passages if you go that way.
    A local guy races commodore engine in speed way and gets about 600hp out of them.
    he works at the machining place so can do all this.
    MUST have torque plates to to the machining or nothing will be round.
  17. #17
    Set of thongs
    Dec 2005
    Stonedville
    Quote Originally Posted by centy View Post
    torque plates?
  18. #18
    VP Executive R-spec
    Jan 2005
    powerslave has his engine for sale I think? it's a 140 rwkw V6, But you will need much more power than that to beat the 5 litre with 140
  19. #19
    Vp series 2
    Jun 2008
    plates that they bolt to the block or head to pull the block/head into the shape it will be in when assembled.
    Apparently the v6's warp when assembled and tensioned so good machinist use torque plates to prewarp the block so when they bore and hone it it will be round when assembled.
    same thing when line boring and doing valve guides and seats if you want it right.
  20. #20
    Vp series 2
    Jun 2008
  21. #21
    Set of thongs
    Dec 2005
    Stonedville
    never heard of that centy, if its bolted in correctly and the tool is sharp and coolant is applied there should not be any chance of the bore going oval. never had the oval problem with line boring either. unless u have a clapped out machine with excessive backlash
  22. #22
    Pub247's Avatar
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    torque plate boring and honing is nothing new any decent machine shop should use this it simulates a head being bolted on so your bores and nice and true
    i dont know what your talking about with guides and valve seats. I think you should noy beleive everything you read and working in a business reconditions motors teaches you more than the internet can....
  23. #23
    savage1987's Avatar
    savage1987 is offline fail champion
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    another thing to help you beat him is learn how to drive it like you stole it and have the cops chasing you.
    load up box and diff when taking off from a start.
    Yep, rule with a VN seems to be to load it up so hard the body begins to groan/creak.. if you don't get to that point, your foot is not hard enough on the brake.
    WTB: mulberry VN interior parts
  24. #24
    Vp series 2
    Jun 2008
    you can go just a little more if you realy try.
    The american have been working these engines for big power many more yeatrs then we have so are the best place to go for answers.
    Also local engine reco guy has and uses torque plates for his work.
  25. #25
    4.2 vt executive
    Aug 2009
    stroker kit with heavily ported heads and good exaust and you should beat him
  1. How do i pull the cd player out?
    By vs_commy5506 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-07-2009, 11:40 PM
  2. vr strusts how do you pull them apart
    By sik-holden in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-09-2008, 12:46 AM
  3. What did i pull off my VN?
    By Wesleyrpg in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-01-2006, 05:42 PM
  4. How NOT to pull a car from the snow
    By ozute in forum The Pub
    Last Post: 29-07-2005, 11:06 AM
