Are MSD coils any good for the vp v6?Improved performance at all?What about thier spark leads?Cheers guys/girls.
CAR ,Y U NO FIX YOURSELF
MSD spark leads are one of the best and their coils are stronger than the std V6 coils.
But if your ignition system is in good order (no missing under load etc) then neither are needed.
People do report power gains sometimes when fitting upgraded ign parts but mostly the extra power is due to original parts being worn out in the first place.
HSV VZ LS2 Senator, Stealth2 cam 307rwkw.http://forums.justcommodores.com.au/...ados-blue.html
VS11 Berlina L67 super6 wagon 196rwkw. http://forums.justcommodores.com.au/...ified-cai.html
Cheers Surfwagon.
supercharged coils have a higher spark than both standard and msd
So no noticable difference than normal if its running well now.....not an upgrade?
So can i put supercharged coils in a normal v6 though?
yes you can but once again its pointless unless you need bigger sprk for instance running a supercharger or turbo
Originally Posted by Smidy
I sure am glad for the truthful advice unlike the so called experts in the shops.Thanks guys.
