Results 1 to 3 of 3
Thread: Parcel Shelf
    G4orce's Avatar
    G4orce is offline HSV Owner
    Vy Senator Signature 5.7lt auto
    Aug 2004
    Melbourne SE Subs
    Default Parcel Shelf
    Hey guys I just built a new parcel shelf for my Vp Calais and it wasnt as had as I originally expected. All you need to do is pull out the out parcel shelf and the rest comes from there. To pull out the old parcel shelf you have to take out the back seats, the brake light and any speaker on the shelf. Then all there is is one or two bolts and a few clips holding it in. Once we got it out I found it was best to peel the carpet off so that i could trace around the shelf. In the old shelf you will see that there are some curves. I cut the two side curves off and kept them. Just trace around onto some MDF anything around 15-16 mm thick. Cut out the shape with a jigsaw and then work out where you would you speakers and cut out the holes. Now with the side curved bit attact them to the side of the new shelf and sand back any bits hanging over the top(these bit are very fragile so be careful). You will need to but carpet to cover the shelf and I found Bunnings had a good variaty. Use contact adhesive to stick the carpet to the MDF. Also remember to cut out a hole to fit the brake light globe through. I left an overhang on the sides and front and back. The over hand was so that the carpet covered any bit the MDF couldnt get to. It worked a treat for me. It is best to screw it your speaker and brake light now or else it is too hard to get to them later. Now test to see if it fits in you car. I didnt need to screw my shelf down it fit snug and doesnt move. The backseat will help keep it in place.I hope this could have help someone and any questions you have just ask in a reply and ill try to help you out.
    My Beast VY Senator Signature 5.7lt Auto
    More info Click on like below
    azkwazere is offline Ahhh Yes, Ahhh Yes....
    VP 5-SPD / 24-SPD Racer Hybrid
    May 2005
    .....SE Burbs
    Default Goodjob
    Good job mate, i broke mine pulling it out...yeh got impatient! i waould like to do the same but add some cool neon display thingy to it...
    anyway, good work..oh can you tell me how to get the back seats off??
    Thanx aZk.
    VpV6 is offline Banned
    VP II Executive
    Feb 2005
    excellent work there mate!
    -- To remove the back seats, you start with the bottom cushion. About level with the drivers and passenger seats there are two clips that hold the bottom cushion in. If you push the bottom of the centre cushion back (in one location at a time) and pull up you can pop off the clip. Now just carry the cushion out and you will see the two bolts that hold the back cushions in. Undo them, lift the cushions upwards then out!
  1. wtb vn ss parcel shelf
    By bMcgrath84 in forum Swap / Wanted to Buy / Trade
    Last Post: 29-01-2008, 07:36 PM
  2. sub in parcel shelf
    By dijm8 in forum Car Audio
    Last Post: 07-04-2007, 04:13 AM
  3. Vr Parcel Shelf
    By Wire in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-01-2006, 05:37 PM
  4. Parcel shelf
    By G4orce in forum Car Audio
    Last Post: 01-07-2005, 10:29 PM
