just wondering how to take out the front left hand side corner indicator, and put in a new one
All ya have to do is twist the little plastic bit behind it that holds the bulb in it and pull it out. Should be pretty easy, cheers
If you need to replace the globe, its as simple as explained above.
If you need to replace the whole unit, you might need to take the whole headlight assembly out, since the indicator slots into the headlight.
Originally Posted by davway
