Results 1 to 7 of 7
Thread: Can you upgrade instrument panel?
    AJM Guest
    Default Can you upgrade instrument panel?
    I recently purchased an '88 VN. The instruments are a bit sick, no temp guage and both fuel and speedo operate sometimes. As I have to replace faulty instruments, can anybody tell me if it is possible to upgrade with a better set that includes tacho and other guages? I am hoping this would not require the wiring harness in my VN executive to be modified to support tacho signal etc.
    AJM
    VX SS 5.7L M6
    Jul 2005
    W.A. Perth
    VT SS 5.7L Commodore.
    Feb 2004
    NSW, Australia
    I am pretty sure, if you can get hold of a level 2 dash from a V6 VN the tacho should work.
    Cheers,
    Jim
    VX SS
    Oct 2004
    Mandurah W.A
    s0sage's Avatar
    s0sage is offline Posting aimlessly ..
    MX6 - Turbo .... so flame me
    Mar 2005
    all clusters from all model vn's and vp's and toyota lexcens and all their sub models (berlina spac exec vacationer csi etc) will slide straight in and work without a hassle.. providing the fault is with the cluster and not your sensors or dash itself..
    ALL EXCEPT CALAIS (ELECTRONIC) WHICH REQUIRE MODIFICATION
    Oct 2004
    Padbury, Perth
    While we are talking about these clusters can anyone tell me the difference between the cluster for the V6 and the V8. People tell me they are different but cosmetically I can't see any difference. It must only be with the tacho cos there will be 8 pulses in lieu of 6 with the V8. I presume the Tacho is fed from the ignition pulses. I have both but I still can't see the difference.
    94 vr 5sp, 04 vz wagon,82 vh efi wagon,88 vn 5sp
    Nov 2003
    northside brisbane
    basically the tacho and the temp gauge are different between the two engine types.
    Temp will still work but will read a little different but the tacho is different and either has to be modded or changed to be accurate.
    This is my vr that I rebuilt ....CLICK HERE to see my vr on Cardomain ......if you want to check it out......Anyway make sure you rubbish a ford daily ....I am a 4DH8RZ Club lifetime member .................new members joining everyday
  1. digital instrument panel
    By The Darkness in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-09-2007, 10:31 PM
  2. problems seeing instrument panel
    By harry3 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 19-10-2006, 10:10 PM
  3. Coloured instrument panel globes
    By Astro_Ghouls in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-07-2005, 08:59 PM
  4. Replacing instrument panel globes?
    By ninja in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-06-2005, 05:05 PM
  5. Removing Instrument Panel.
    By Combo in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-02-2004, 11:46 PM
