Results 1 to 6 of 6
Thread: strut top off without a rattle gun????? help please
    millaz88's Avatar
    millaz88 is offline wishin me v6 was blown :)
    vn commodore
    Sep 2009
    gippsland
    Default strut top off without a rattle gun????? help please
    hey goin to be puttin lowed springs in my car dont have a spring compressor tho i was just goin to jack the strut up under the car and undo to strut top and then lower it down slowly but it seems hard as to undo the nut can u do it without a rattle gun?
    VS l67 statesman
    Dec 2008
    Can be done but depends on the car and how long and tight its been put on ,I usualy get them off by a 3LB hammer and a good sized rachet and socket give the rachet a good joilt with the hammer to crack it
    VS Berlina 3.8
    Dec 2008
    Are you putting shortened struts in? Mine were dead, so we just cut them off with an angle grinder, as the new struts came with new bolts.
    millaz88's Avatar
    vn commodore
    Sep 2009
    gippsland
    yeh im putin new shocks n springs in tomoro found a rattle gun(thanks to a mate) so hopefully its all good
    rickybobby's Avatar
    rickybobby is offline shake 'n' bake
    VN S1 V6 T5, VR V8 T5
    Aug 2008
    MEL
    i tried everything - bought go-thru sockets, welded shock pin to stop it turning, etc...
    after 2 weeks i eventually cried to a mechanic bud for advice and he laughed at me - just like he laughed with the ball joints.
    he lent me his grunty rattle gun - it was the way to go for me as it shocks 'em loose.
    it worked and i felt like a winner...but then i tried the the rear suspension lower control bushes and ended up in tears again.
    the vn enjoyment never ends.
    Vp series 2
    Jun 2008
    lol mate slip the rubber up on the strut and grab with vice grip if you are replacing them.
    the lower bushes you WILL need a rattle gun to do.
    I'm 130kg and could not get enough pressure one the ratchet to get them in, a good rattle gun and it was all over. remember they are tappered and you need a c shape bit of tube to stop from crushing the brackets together. not to hard just need a littl planning to do.
  1. VR Rattle
    By lgnd3800 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-10-2007, 10:43 PM
  2. vx rattle
    By Mark VX-S in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-11-2006, 04:59 AM
  3. Strut Top removal with no Rattle Gun
    By 308vkcalais in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 15-10-2006, 08:39 PM
  4. Door Rattle - Yes the Rattle that hunts Holdens
    By Ratty in forum VY Holden Commodore (2002 - 2004)
    Last Post: 27-05-2006, 09:01 PM
  5. VR Fan Rattle
    By ashley_salta in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-10-2004, 12:10 AM
