Results 1 to 12 of 12
Thread: Converting au twin fan to fit vp
    vp
    Sep 2008
    Talking Converting au twin fan to fit vp
    ok so i got bored lol so went to the wreckers and got a ford au twin fan trimed it a lil and wired my old vp fan plug on the au fans and put a other fuse 40a and changed all the fan fuse to 40a and off i go lol Converting au twin fan to fit vp-p221009_13.23.jpg
    savage1987's Avatar
    savage1987 is offline fail champion
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    Did you switch the relay to a 40A?
    I used a 35A blade fuse upgrade BUT it's melted
    I did my wiring the same as you have
    edit: my wiring isn't quite the same. I just bridged all the AU wiring to the VN plug, didn't run a fuse for each fan
    WTB: mulberry VN interior parts
    VS 96 Exec Wagon
    Jul 2009
    Queensland
    do you find Twin-Fan works better than the stock Vn-Vp one?
    Paintball.. It's not just a Sport.. It's a lifestyle!
    Check out my VS Wagon !
    See my Re-Mixes here YouTube - Dtek5
    savage1987's Avatar
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    Much better but it takes a fair bit of trimming and imagination to mount them properly.. my charcoal canister is still only held up by cable ties.
    vs ss manual
    Jul 2009
    gosnells
    savage1987's Avatar
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    vs ss manual
    Jul 2009
    gosnells
    sam dont ruin my fun i dont want ford parts haha which by the way the ba ford falcon interior light also fits into my vs funnily enough it has gm and ford stamped on it
    vp
    Sep 2008
    [QUOTE=savage1987;1336535]Did you switch the relay to a 40A?
    edit: my wiring isn't quite the same. I just bridged all the AU wiring to the VN plug, didn't run a fuse for each fan[/QUOTE
    nar just switched the fuses to 40 think its coz u dont have a fuse for each fan its getting more power then it needs thats y i put 2 in and it works fine
    vp
    Sep 2008
    savage1987's Avatar
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    Quote Originally Posted by kaneovp View Post
    OK, can you give me a basic layout of how you wired it? I have trouble with electrics I don't really 100% understand relays.
    VH COMMODORE 308
    Jun 2009
    I recently set up au fans they work great but you need to run
    through a relay and have a source trigger the relay like ignition etc.
    you can also run a davies craig thermo switch which is fully adjustable.
    look here all the info you need and wiring diagrams http://www.daviescraig.com.au/Images...(08-08-06).pdf
    savage1987's Avatar
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    Mine are running through the relay for the factory V6 fan, triggered by the ECU. I just need to sort the wiring out but that can wait a couple of weeks, for now I am going to LONDON BABY
  1. [VIC] Wtb: Exhaust tip..twin dumps/twin chrome/oval
    By fkford in forum Swap / Wanted to Buy / Trade
    Last Post: 15-10-2009, 09:12 AM
  2. Should i get Berkley twin 21/2 into twin 2 1/4?
    By mrvx2 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 18-05-2009, 11:31 PM
  3. VT twin fan versus AU twin fans question
    By FXST01 in forum Electrical Wiring / Questions
    Last Post: 25-10-2006, 12:12 AM
  4. Converting My VL to LPG
    By Aussie_Watto in forum VL Holden Commodore (1986 - 1988)
    Last Post: 15-03-2006, 09:23 PM
  5. Converting my VK to gas
    By Foordy in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 21-11-2005, 09:22 AM
