Results 1 to 7 of 7
Thread: Please someone help....
    2011 Ve clubsport
    Oct 2009
    Wagga Wagga
    Unhappy Please someone help....
    My vn v6 starts and runs fine but every now an then whilst driving it like chokes its elf and stalls. stop and start it again and its fine?
    pow3rslave's Avatar
    pow3rslave is offline DoNothing Member
    VP 5.0L
    Oct 2005
    eastern subs, vic
    1988 VN Executive S1 and 1984 VK Executive
    Sep 2008
    South Australia
    1993 Series II VP Calais
    Sep 2006
    Interesting... A very similar thing happened to my VP just yesterday. Turns out I have a lot of gunk in my fuel tank, and it was clogging my filter. Every 5km on the way home, the car would stall, I'd backflush the filter, put it back in, and keep driving. It was horrible, but it now means I need to get my fuel tank flushed, get a new pump, new filter, and probably get new injectors coz of the shit I put through them backflushing my filter.
    So, I recommend you pull your filter off and note the colour of the fuel coming out. Mine was dark brown =)
    NOT.BT1's Avatar
    NOT.BT1 is offline Bogan pride
    VN exec project vh in the shed
    Nov 2006
    geelong victoria
    i had a similar problem with my vn except it stalled when i was backing off the throttle to slow down or turning a corner it turned out to be the throttle position sensor
    Quote Originally Posted by neet_wagon View Post
    Instant Failure!
    What exactly IS a VD commodore? Is this some super hektic cop-special I've been missing out on?
    Quote Originally Posted by ari666 View Post
    basically OP is saying he has VD in his crapbox???
    didnt know you could get herpes of the anus, but hey! who am i to judge. have fun with your herpes OP!
    PaRaDoX's Avatar
    PaRaDoX is offline boosted!
    Forester GT, VT S Supercharged, Supra Turbo
    Apr 2005
    Melbourne, Victoria
    Quote Originally Posted by 89vn View Post
    Search up what happens when a DFI module fails, its pretty common.
    sounds like the issue to me.
    strgas's Avatar
    strgas is offline GRA = REAL HP
    Oct 2009
    common problem for stalling on deccel and turning was base idle incorrect , fuel pumps are a known problem too car stalls out get out kick the tank and away it goes for another 10kms , check your fuel pump fuses and relays swap the relay with the horn relay as this does very little work is the car on gas ??
