Page 1 of 2 12 LastLast
Results 1 to 25 of 28
Thread: Loud high pitched noise near back drivers wheel on vp????
    VT Berlina Wags
    Aug 2009
    Bellarine Peninsula
    Default Loud high pitched noise near back drivers wheel on vp????
    I have an average to loud high pitched noise sounds like its near my back drivers wheel or just behind it???? Any ideas what it could be? This is all when the car is parked and not moving???
    CAR ,Y U NO FIX YOURSELF
    Zuicider is offline Banned
    Set of thongs
    Caribbean Stud Poker Champion!
    Dec 2005
    Stonedville
    markER717's Avatar
    markER717 is offline Un-Donated Member
    1990 3.8L VN Calais S1
    Jun 2009
    Geelong, Victoria
    If its a squeal its probably a bearing. I think there about 15ish bucks from memory, It was a while ago I was looking to buy some so I could be wrong.
    pow3rslave's Avatar
    pow3rslave is offline DoNothing Member
    VP 5.0L
    Oct 2005
    eastern subs, vic
    Quote Originally Posted by Zuicider View Post
    a burn out?
    lol.
    OP, is it constant? does it happen stationary or only at speed? checked brakes and handbrake?
    VT Berlina Wags
    Aug 2009
    Bellarine Peninsula
    I like your thinking Zuicider but i think thats a noise that i am only too familiar with and its not that one this time......Its funny because the noise is there weather the car is in park or drive????
    VT Berlina Wags
    Aug 2009
    Bellarine Peninsula
    Set of thongs
    Dec 2005
    Stonedville
    pow3rslave's Avatar
    VP 5.0L
    Oct 2005
    eastern subs, vic
    stationary only from the rear drivers side? it could be the fuel pump or a line, but i've never heard of them making a noise like this
    VT Berlina Wags
    Aug 2009
    Bellarine Peninsula
    No its like an air leak kind of whistle (high pitched if you know what i mean)but the tyres are all fine and exhaust seams ok the car is not moving and i can walk around the car and the noise is located roughly insidethe wheel arch or perhaps a little further under the car.Kind of sounds a bit like a pump noise maybe but whats back that way that could be doing that?
    VT Berlina Wags
    Aug 2009
    Bellarine Peninsula
    As soon as i turn the key its there.Even before the car fires properly i can hear it.
    VT Berlina Wags
    Aug 2009
    Bellarine Peninsula
    Hey guys its only there on petrol so the fuel pump or line might be right.If i replace the fuel pump and its still there then what can i do with the lines?
    thedeadwalk's Avatar
    thedeadwalk is offline thedeadwalk
    VS executive S2
    Sep 2009
    newcastle
    my 2 cents is it's all in your head man
    or some one's left a mobile phone with one of those shit ring tones man
    VT Berlina Wags
    Aug 2009
    Bellarine Peninsula
    I wish that were the case but its not just me its my mates and a bloke across the road who reckons its probably the fuel pump as it only happens on petrol.
    pow3rslave's Avatar
    VP 5.0L
    Oct 2005
    eastern subs, vic
  15. #15
    VT Berlina Wags
    Aug 2009
    Bellarine Peninsula
    I have not replaced anything to do with fuel....its the first time since i purchased the car that i have left it to run on fuel for a while and the noise was there from starting it up this morning.Took it for a spin and came back,the noise is still there and annoying me so i will fit a new fuel pump and filter and see if it goes away.Whats a good fuel pump mate?V6 of course.
  16. #16
    Jul 2008
    fuel pump bro, when they start dieing they make some pretty funky noises , either replace it or drive it till its dead, the worst that could happen is ya car will stop, unless you gots dual fuel
  17. #17
    VT Berlina Wags
    Aug 2009
    Bellarine Peninsula
  18. #18
    VS 96 Exec Wagon
    Jul 2009
    Queensland
    If its not a Burn Out.. lol I'd say its your Fuel Pump or Wheel bering ;p
    Paintball.. It's not just a Sport.. It's a lifestyle!
    Check out my VS Wagon !
    See my Re-Mixes here YouTube - Dtek5
  19. #19
    VS 96 Exec Wagon
    Jul 2009
    Queensland
    For fuel pump im sure you gotta drop the Fuel Tank (?)
  20. #20
    VT Berlina Wags
    Aug 2009
    Bellarine Peninsula
    That sucks because now i have to do burnouts until i run it out of fuel(lol).Then i can replace my tyres and the fuel pump.
  21. #21
    markER717's Avatar
    Jun 2009
    Geelong, Victoria
  22. #22
    Commydoor's Avatar
    Commydoor is offline born in the FB era
    Vr Ss Blown
    Sep 2007
    Beresfield, NSW.
    did you fix it yet?...another possible is a blocked breather pipe from the tank or an incorrectly fitted one....fuel comes out air cant get back in vacuum is created and youd get a squeal as it tries to suck air back in.....when it does it again take off the fuel cap and see if it stops....
  23. #23
    VT Berlina Wags
    Aug 2009
    Bellarine Peninsula
    I will try it tomorrow morning and let you guys know what happens...cheers for the help so far.
  24. #24
    savage1987's Avatar
    savage1987 is offline fail champion
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    Quote Originally Posted by Timsgmh View Post
    100% it's the fuel pump from the description the OP has given. No other theory stands because most of the suggestions here were from people who hadn't actually read the conditions of the problem. The noise won't still be there when the pump has been changed. Not as badly anyway - they do all whine to some extent, it's not meant to be loud though.
    Quote Originally Posted by Commydoor View Post
    It won't be a blocked breather if it starts the instant the pump is priming.
    Probably not a bad idea to replace all your breather lines while you have the tank down. Allow a Saturday to get it all sorted out if you don't know what you're doing.
    WTB: mulberry VN interior parts
  25. #25
    Commydoor's Avatar
    Vr Ss Blown
    Sep 2007
    Beresfield, NSW.
    any luck yet?
  1. High pitched whining noise coming from Engine Bay
    By rokkz in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-07-2011, 10:23 PM
  2. High pitched noise
    By nick3110 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-07-2009, 04:55 PM
  3. Ign on, engine off, high pitched noise
    By jjl in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 08-06-2009, 05:22 PM
  4. High pitched sound coming from front left wheel when turning
    By RonMan in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-03-2009, 10:45 AM
  5. Replies: 5
    Last Post: 14-08-2008, 01:59 PM
