Results 1 to 16 of 16
Thread: VN S1 VS's S2
    VL EXEC
    Aug 2008
    perth wa
    Default VN S1 VS's S2
    just wondering what the difference between the s1 and s2 vns are if this has been posted previously feel free to send me in the right direction
    I've driven fast cars I've done stupid shit in them each time i seem to come out on top i love you guardian angel
    vp ss 3 months to go
    VL EXEC
    Aug 2008
    perth wa
    im talking about the buick nots the 304s cheers guys
    LordMayhem's Avatar
    LordMayhem is offline Here For A Good Time!
    VN Calais
    Jan 2009
    Hervey Bay QLD
    radiator setup and where the thermostat is on the intake manifold apart from that not alot i think (thermostat on an S1 is at the rear under the throttle body S2 it is at the front.....S1 has a pressurised overflow tank and no radiator cap on radiator S2 has a radiator cap)
    VN Calais With All The Factory Fruit I Need!
    STEALTHY™'s Avatar
    STEALTHY™ is offline So Wet For You!
    VP Calais International, VP Berlina LX Wagon
    Jan 2005
    SA - The Roadworks State
    No difference. No such thing as a series 1 or series 2 VN.
    Theres early and late (aswell as a 3rd different 'update' (lol series 3))
    Quote Originally Posted by davway
    Improved Suspension Reduces Handling!
    Quote Originally Posted by JONNNNOOOOO!!
    cheers sexy
    VL EXEC
    Aug 2008
    perth wa
    Quote Originally Posted by STEALTHY™ View Post
    fair enough but i heard the early models were a bit more torquie under early revs causing the old people to do burnouts and shit so they retuned them true or false?
    VP Calais 5ltr
    Sep 2009
    West Melbourne
    I may well be way of track but from what I can recall the 88 vn had a different motor.
    And yes I can say they were pretty well know for breaking traction. I had one for my second car.
    INNAWE (in awe)
    Noun 1. awe - an overwhelming feeling of wonder or admiration; "he stared over the edge with a feeling of awe"
    2. awe - a feeling of profound respect for someone or something; "the fear of God"; "the Chinese reverence for the dead"; "the French treat food with gentle reverence"; "his respect for the law bordered on veneration"
    VL EXEC
    Aug 2008
    perth wa
    Quote Originally Posted by INNAWE View Post
    it was still a buick i just think it was either tuned differently or the compression was different cant remember tbh
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    the early VN's have a different cam and tune. for the later VN's they changed the cam to a slightly longer duration but with less lift. the net result was the same power but a slightly different torque curve that starts higher in the RPM range. on the early VN's the rockers use a different size bolt, the cam uses a different flange, the timing cover is slightly different (coolant passages/water pump) the obvious differences of the intake manifold/cooling system and PVC. there are also some slight wiring changes including the DFI and coil pack, the CAS and the harmonic ballancer (later VN's onwards they become a press fit)
    infact Holden changed things right through the production run of the VN. check the VN/VP history thread. it details all the production changes with dates etc
    Body by Holden, Soul by Brock
    the Legend will live forever
    VL EXEC
    Aug 2008
    perth wa
    out of curiosity if planning on doing forced induction on one what would be better and dont say a v8 im just curious
    Apr 2006
    Auckland NZ
    2tenths of **** all differnce when you add FI
    VL EXEC
    Aug 2008
    perth wa
    lol fair enough in that case ill just find an 8 ^^ dont know why i was expecting much of a difference really
    VN Production Saloon
    Mar 2009
    Gisborne NZ
    Different block - S1 dog turd (rope) rear main seal
    S2 one peice seal - you can hook it out without dropping the
    sump and taking off the rear main cap. EV6 cast on side of block
    Different cranks- S1 six bolt rear flange, different man/auto.
    S2 eight bolt rear flange, same man/auto.
    (covered here V6 Crankshaft Info )
    Different Heads - extra passage on S2 intake face, double springs on S1 singles on S2
    Oil pressure relief spring - stiffer on S2
    Hideous factory 'headers' on S1, cast manifolds S2
    and as mentioned in previous posts , no doubt theres more too
    STEALTHY™'s Avatar
    Jan 2005
    Quote Originally Posted by VNracer34G View Post
    like i said, technically theres no difference, cause neither exist
    cheers sexy
    rob drag racer's Avatar
    rob drag racer is offline vn vp drag nut
    vp 3.8 with gas new project vn s1 guted strip only
    Jun 2008
    golden beach
    Default my s1 vn
    my s1 vn has alot more torque than my old vp race car YouTube - vnminispool
    i wont tolerate cretins aiming to cause problems here at jc and nor will i hesitate to let the moderators know
    http://robsbackyarddragraceing.bigblog.com.au/index.do
  15. #15
    VN Wagz's Avatar
    VN Wagz is offline PshhhhHHT- **TuTuTuTu**
    VN Berlina V6 Wagon
    Sep 2008
    Dunlop (North Canberra)
    VN S1 engine- torque monster with different shape intake manifold (plenum and runner shapes are different, but visually hard to tell from above), different cam, no restrictor into manifold from TB (which S2 had). Generally ran outta puff about 4500, whereas the S2 motors were good to make power to approv 4800-5000ish.
    Small piece of trivia (cant remember where from tho? LOL) >
    The original 88 vintage VN V6 made more power and torque than the VL 3L turbo engine everywhere until its 4400rpm peak, after which the silky smooth RB kept pulling. to make the additional 25kW (125kW vs 150kW respectively).
    And if i remember, the VN manual was credited with some very fast 1/4 times in both auto and manual form in its initial testing- mid 15s? Which was the same as the VL turbo.
    Oh, and the tune in the ECU for the S1 was a bit more aggressive in its low-end fuel and ignition mapping> im running the ECU from my brother's 88 Vn in my S2 VN wagon, when it was jsut n/a it did give her a bit more "snap" down low (i got from a 16.2 to a 16.03 at WSID just from installing the S1 ecu).
  16. #16
    savage1987's Avatar
    savage1987 is offline fail champion
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    Plenty of changes along the way, plenty of places to read about them too. Do a search, although luckily some people have covered it quite well here. If planning FI, it won't matter which engine you get, so just take a later one for ease of changing plugs on the driver's bank (very annoying on the early models)
    WTB: mulberry VN interior parts
  1. A couple of VS's
    By vsutespack in forum General
    Last Post: 08-11-2009, 06:55 PM
  2. which vs's came with the super 6 (L67)
    By (CODEZ) in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-07-2009, 06:46 PM
  3. abs on vs's?
    By pow3rslave in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-07-2009, 01:56 PM
  4. Used VR/VS's...how many km is too many?
    By Rzeractor in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-06-2006, 11:03 AM
  5. vs's for sale??
    By stock_vl in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-09-2005, 01:29 AM
