Hi all, I need some help to solve my problem. My 1992 vp v6 cuts out when I go around tight corners.at slight speed Or roundabouts It's like it stalls, it happens every time my fuel gets to half a tank and under. Wen it's full problem not there.it is starting to piss me off now. Any help on this matter woul b greatly appriciated. Cheers Marty
Could be a number of things. Have you done a faults check yet?
Could be your ECU, Fuel Pump.
Stupid question mate, but do you have a Taco that was recently installed, because we had the same problem not so long ago and it was the bloody taco. Just a thought, good luck on finding the problem.
common problem to do with either the fuel ruturn line in the tank going to the swirl pot or the plastic swirl pot itself in the tank is broken
Hey delco, got my tune the other day and put it in, wot a diffrence it has made Through the whole rev range. I'm happy as a pig in shit haha thanks bud.if anybody is thinking off getting a delco tune do it, best money u could spend my old girl has woken from her sleep. Thanks bud. Now the hose problem u were refering to, how do I fix it.?
never had to fix one myself theres been talk of new tanks etc its been covered a little on here serch with google youll find somethingi just pmed you to see if you sent the memcal back yet people have been slack and im running out good to see she goes
if its just the return hose and you have small hands that will fit in the sender hole you may be able to replace it
