my vq is not in a easy place to get at the starter and am having trouble locating the starter bolts. i found 1 vertical bolt but cannot find another.
there' both vertical, if you can find the edge that the bolt you took out is on, the other should be on that same edge.
if you're under the car looking up, one should be on the left of the starter motor, one on the right.
Always helps to take both bolts out of the steering rack and slide it back a little![]()
The 1972 HQ Kingswood
Thank you guys. Found it straight away!
