Results 1 to 8 of 8
Thread: VN Front Knock, Squell and Vibration HELP PLEASE
    Vr S2 Calais
    Jan 2009
    Default VN Front Knock, Squell and Vibration HELP PLEASE
    Hi all i have a Vn commodore 1989 sedan i only recently replace my tie rod ends and after i replace them every time i turn a corner i hear a squeel from the front and i also have steering wheel vibration when i take off fast and also have a a knock when i reverse out a drive way on the drivers side recently replaced shocks but what im consender about is the squeel any ideas guys
    VN commodore S1 & VXII Berlina LS1
    Jan 2009
    Vr S2 Calais
    Jan 2009
    na mate no wheel alignment done would that be the problem as i also replaced me front shock about 2 weeks ago with the top bearings because it started asoon as i replaced me tie rod ends
    Vp series 2
    Jun 2008
    can i smack you in the head now?
    you change shit on the front suspension then you get a wheel alignment, or you go buy a ford and i won't give a rats arse.
    VS 96 Exec Wagon
    Jul 2009
    Queensland
    Dont worry, easy mistake
    Needless to say, i learnt the hard way to
    Paintball.. It's not just a Sport.. It's a lifestyle!
    Check out my VS Wagon !
    See my Re-Mixes here YouTube - Dtek5
    Vr S2 Calais
    Jan 2009
    Vr S2 Calais
    Jan 2009
    Hi All well i went to take it for a wheel alignment yesterday and the bloke said i need a new rack end on driver side tie rod end and Lower Control arm bushes, front and rear Radias Rod Rubbers i have put them all in and took it for a test drive around the block every time i put my foot on the brake i get a knock i was wandering if i have done something wrong or it needs a wheel alignment which is what i am doing tommorow or is there another problem is it because the rack end needs adjustment or something along the lines of that any help would be great
    VR S2 Commodore remote turbo
    Nov 2009
    Mount Isa
    I have done the same as vr929 replaced everything the the front end down to the rack, struts, bearing and bushes i did get a wheel alignment day after work was done. the bloke said that it all looks great aligned well car drives sweet, let go of the wheel drives straight... now when i stand hard on the brake before a corner thats when i get a loud sinlge knock every time as the car dives down off the brake round the corner on the power and a small knock as the car straightens and levels. i didnt have this before the work was done i've gone all over everything i have done and it all looks good and tight... it's got me stumped
  1. VNSS front end knock
    By H00LiGaN in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-11-2009, 08:57 AM
  2. Theres a knock in the front end.
    By INNAWE in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-11-2009, 09:43 AM
  3. VT front end knock
    By spiro in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-07-2008, 04:33 PM
  4. Front End Knock?
    By VT Berlina 07 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-09-2007, 05:40 PM
  5. vs front end knock
    By richy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-05-2004, 11:12 PM
