Results 1 to 17 of 17
Thread: And another issue.. CAS?
    VS 96 Exec Wagon
    Jul 2009
    Queensland
    Angry And another issue.. CAS?
    Howdy again lol!
    Right, so i've put new injectors in!! Not leaking anymore!
    However, the fail start up is still persisting..But, this time it's not coughing out back fuel smoke via the exhaust anymore
    So, when I go to start the car up, she winds and winds..Each wind sounding closer to start up, but when it does for the first few secs.. it's like the engine is trying to escape.. its making thumping noises that really shakes the shit outa the car lol..
    A few buddies of mine, suggest its the CAS (Crank angel sensor) it's dying..
    Just asking, is this true?
    Or is there a way to fix it before, I order the CAS ?
    Im also thinking , the starter motor could be kicking the bucket aswell..
    Any help is appreciated
    Thanks lol
    mark.
    Paintball.. It's not just a Sport.. It's a lifestyle!
    Check out my VS Wagon !
    See my Re-Mixes here YouTube - Dtek5
    Dangerous Dave is offline Donating Member
    VS Berlina
    Mar 2009
    Once it finally does start, how does it run??
    Can you get a loan of a fuel pressure gauge and see if your fuel pump is running up to pressure ??
    VS 96 Exec Wagon
    Jul 2009
    Queensland
    first few seconds is really rough! then after a bit of throttle it sorts it self out.
    But when it stops at red lights etc etc it will begin to make a knocking sound
    Havent tried a fuel pressure gauge..Where do i put the gauge in tho? never done it before
    WogBoyz's Avatar
    WogBoyz is offline Cammed & Eventualy Blown!
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    id get ur fuel pump checked, also it could be the CAS if there not expensive id change it anyway if it hasnt been done before
    Now Saving for a Harrop HTV2300 Supercharger kit!
    Quote Originally Posted by skyracer View Post
    On new years eve I got stopped by a pack of about 5 people forming a road block. All of them naked. They proceeded to turkey slap my car as I rolled past...
    VS 96 Exec Wagon
    Jul 2009
    Queensland
    I suppose it wouldn't hurt to get fuel gauge anyway lol. But, if I do get one..What should the gauge be sitting on, "Lean" - "Stoich" - "High" ? (Looking at this one - http://www.supercheapauto.com.au/onl...155249#details)
    OR! if it has number indicated ones, what should it be sitting at?
    Fuel pump, is stock..And has been running VERY Close to Empty once..As I was outta town and forgot to re-fill before leaving ... But, it's quiet..not loud or anything. But, being so close to E it would not surprise me if i've farked it lol.
    As for CAS, it's about $50 to buy it, plus $60-70 for a mech to put it in..
    Once this is done..She will be all good
    WogBoyz's Avatar
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    Quote Originally Posted by Dumster View Post
    I suppose it wouldn't hurt to get fuel gauge anyway lol. But, if I do get one..What should the gauge be sitting on, "Lean" - "Stoich" - "High" ? (Looking at this one - Calibre Gauge - Air/Fuel, 60mm - Supercheap Auto)
    when you turn the key on, before you start the engine, do ya hear the fuel pump prime?
    VS 96 Exec Wagon
    Jul 2009
    Queensland
    Yep I let it prime before I fire the engine up
    WogBoyz's Avatar
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    pump sounds like its all good then, id get ya cas replaced then see how it goes
    VS 96 Exec Wagon
    Jul 2009
    Queensland
    will be Im sure it's the CAS. as the engine makes a knock sound wile sittin, not hard..but noticeable :P
    Like a mate of mine with a VS had a rooted CAS, and his shook like theres no tomoro LOL
    VS 96 Exec Wagon
    Jul 2009
    Queensland
    thank's to Hozy..Further investigation is pointing towards Coilpack and/or DFI module..
    When the rain stop, i plan to do a spark test
    bpefi is offline Tech
    Hilux Ute - Vs Ecotech Engine
    Nov 2009
    Bundaberg
    Hi all I would be looking at coils first any good mechanic should be able to test these - They seem to fail regularly
    VS 96 Exec Wagon
    Jul 2009
    Queensland
    wouldnt be free by any chance would it ?
    VS 96 Exec Wagon
    Jul 2009
    Queensland
    rigt.. the coil pack and/or DFI is shagged lol..
    Zuicider is offline Banned
    Set of thongs
    Caribbean Stud Poker Champion!
    Dec 2005
    Stonedville
    did u get a mech to test the resistance? in the coils? because if your cas is fried u wont be getting any spark
  15. #15
    VP Executive R-spec
    Jan 2005
    Your balancer is shagged, as for the hard to start I'd would have said leaking injectors but since you have new ones maybe not
  16. #16
    VS 96 Exec Wagon
    Jul 2009
    Queensland
    replaced its coils..and its happy
    still get the odd knock wile idling or stopped.. next, harmonic balancer!
  17. #17
    VS 96 Exec Wagon
    Jul 2009
    Queensland
    welp.. problem has been found. Its fuel related.. I take the fuel pump fuse out..Start the car..Let it stall then put the fuse back in .. Waited 30min. kicks first go.. Highly suspecting fuel pump or damage line :P
    woot. gettin closer!
  1. VZ Oil Issue
    By mainpath in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 26-04-2009, 02:12 PM
  2. VX Series 2 Executive - Start Issue + Boot Button Issue!
    By stig1 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-06-2008, 02:28 PM
  3. VN HSV +6 issue
    By And_ROOS in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-12-2007, 03:25 PM
  4. VN HSV +6 issue
    By And_ROOS in forum Electrical Wiring / Questions
    Last Post: 04-12-2007, 11:55 PM
  5. Cause of an issue???
    By boojak87 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-07-2006, 09:42 PM
