Results 1 to 5 of 5
Thread: Removing trolley strips from your doors?
    Vn Berlina 89
    Nov 2009
    Default Removing trolley strips from your doors?
    hi ive just started working on my 89 vn berlina and on the advice of a friend who used to own a vp berlina i removed the trolley strips from the doors. im just wondering tho since the adhesive is pretty thick ive tried using sonax tar remover and general purpose thinners on the adhesive ive had varied results the lighter patches of adhesive is quite easy to remove but the larger masses of adhesive are more dificult to remove and ive tried to peel it off but im not satisfied this is the best way to remove it as the way ive been peeling it i sometimes get finger nail wide scratch marks. has anyone else done this to there commodores and had a better method? any suggestions would be appreciated
    STEALTHY™'s Avatar
    STEALTHY™ is offline So Wet For You!
    VP Calais International, VP Berlina LX Wagon
    Jan 2005
    SA - The Roadworks State
    Man, berlina's and Calais' have the best stripes. You only remove stripes from an Exec. I'd put them back on
    Quote Originally Posted by davway
    Improved Suspension Reduces Handling!
    Quote Originally Posted by JONNNNOOOOO!!
    cheers sexy
    Fun_Bucket's Avatar
    Fun_Bucket is online now Gay Country Rapper
    Bumming lifts, saving up.....
    Mar 2009
    Cairns White Rock
    I did mine without doing any damage, but i wish i left them on, personally i think it looks better with them on. I boiled the kettle, and poured the water over the strips, and left it for a few minutes. This softened the sikaflex up enough, to pry the moulds off. Once they were off, i used more boiling water, and poured it on the remaining sikaflex , and then used a razor, and very gently, cut the sikaflex down to a very thin amount. When it was thin enough, i was able to remove the rest of it, with prepsol. I reckon it took me about 5 hours to both sides...
    VP Executive R-spec
    Jan 2005
    Even the Execs look heaps better with them on, stick them back on man. Not only do they look better they stop you getting bent doors and that never looks good
    Morton's Avatar
    Fairstar the Funship
    May 2006
    It's true. I had a man dent the door of his brand new Alfa in a carpark once when he swung his door open into one of my trolley strips. All I suffered was a sliced door rubber. They work reeeal good
    The 1972 HQ Kingswood
  1. Removing Trolley Strips
    By Salmon in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 13-10-2009, 10:44 PM
  2. removing trolley strips?
    By Nathan_Vs_1996 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-09-2009, 02:08 PM
  3. Trolley/Black strips
    By Sharoo in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-04-2009, 12:22 AM
  4. Removing trolley strips and sicaflex tip
    By savage1987 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-11-2007, 08:16 AM
