Hi all i have just replace my headlights on my in to the normal Philips H4 cost me $45 at auto barn i only replace them because they were dull but they are still dull what would cause this to happen and how can i fix it all help muchly appreciated
One of the first things i fixed on mine, The reflectors inside the headlights become dulled over time and don't reflect the light very well. You can pick up brand new aftermarket headlights on Ebay pretty cheap, then make sure they are aimed properly using the 2 knobs on the back of the headlights. There should be a guide how to correctly aim them around here somewhere.
Power is measured in DECIBEL
yeah the headlight reflector stuff dulls and gets dirty over time, if you dont wanna spend $120 on new lights heres a how to on cleaning them i wrote a while back
Cleaning Frosted / Dirty Headlights
cheers fellas will clean them as i cant buy new ones yet also could it be an old relay or highly not
not really, from my experience relays tend to work or dont work, they may 'flicker' on and off when they are wearing out. However its always good to make sure your electrical system is up to scratch, dirty battery terminals, poorly maintained batterys, bad earths/connections etc.. can cause voltage drop which will result in decreased light output from your headlights
