Results 1 to 4 of 4
Thread: how to remove vn trans??
    vn Executive
    Jun 2008
    Default how to remove vn trans??
    i know there use to be a wright up on here on removing a trans for a vn cant find it. if someone could find the link it would be awesome. or just give me a quick run on how to do it. i have done one befor but dont wont to **** it up???
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    -undo loom
    -drop fluid (from pan)
    -remove dip stick
    -undo inspection cover bolts (some on sump need to come off to)
    -undo converter bolts
    -undo bell housing bolts
    -remove shift linkage
    -remove tail shaft
    -undo rear trans mount bolts (support the trans with jack)
    and it should come off
    think that's about it.
    VP Exec
    Jun 2005
    And the auto cooler lines at the trans unions. Usually the hardest part of the job.
    Also, remove the speed sensor wiring harness from the clip on the back of the trans or you risk tearing it off the car.
    vn Executive
    Jun 2008
    cheers for the help now if just wasn't so bloody hot. well i guess it will be a little bit at a time.
  1. how to remove/replace auto trans
    By stackner in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-03-2009, 01:31 PM
  2. About to remove this....??
    By nicko in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-03-2008, 11:53 PM
  3. Auto Trans problem when hot - need a trans cooler ??
    By woteva in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-12-2007, 11:41 PM
  4. How to: Install/ Remove gear select changer for auto trans
    By vnberlwagon in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-04-2006, 11:42 PM
