hi
i have a set of pacies that need installing in my V6, but ive been told the s1 is a bit more of a f**k around because there is some hose/pipe (cooling i think) that runs across the manifold.
just wondering if anyone has done it on that model before and howd they find it, best way to go about it?
Want to do it myself but i dont want any surprises while im doing it
cheers.
its not the years in your life, but the life in your years.
You will need to undo the rack and move it over, the coolant pipe that runs to the rear needs to be disconnected moved out of the way as well...sometimes...I know with Genies you don't need to move it even though the instructions say you do.
Go to the Pacemaker site and print off the fitting instructions for the part number of your extractors.
thanks for that, yeah i came accross the installation on the pacemaker site, would be perfect if they had a few photos to go with it.
I should have known you would be the man with the answer, should have just PM'd you directly![]()
Yeah drivers side is abit of a pain, up on ramps or jacked up, passenger is piss easy, make sure its all sealed up to, some high temp sealant wont go astray either. you dont want to come back to the job.
~ VN POWER ~ Click the scales
