Results 1 to 5 of 5
Thread: Spark plug gaps VN v8 LPG?
    GTP 85's Avatar
    GTP 85 is offline 291 hp @ the wheels
    VS track car & VS SSenator
    Aug 2006
    Adelaide, near the bay
    Default Spark plug gaps VN v8 LPG?
    Hi all. What spark plug gaps do i need for VN V8 on LPG?
    Had a quick search and couldn't find anything specific.
    Hit me up with some reputation points if i've helped you out! (Star in the bottom left!) Cheers!
    GT Performance RUF 231- NA 3.8L- 13.30 @ 103 Mph... So far... Cam, compression and revs! MY CAR>> http://forums.justcommodores.com.au/...tml#post471410
    Daily VR SS: http://forums.justcommodores.com.au/...ite-vr-ss.html
    strgas's Avatar
    strgas is offline GRA = REAL HP
    Oct 2009
    GTP 85's Avatar
    Aug 2006
    Quote Originally Posted by strgas View Post
    .8 mm and use a non resistor type spark plug .
    ok thanks! what is a non resistor type? sorry if it sounds stupid, i have no idea?
    strgas's Avatar
    Oct 2009
    BPR6-EFS is a resistor type plug where as a BP6-EFS is not . always with lpg type plug run one heat range cooler as the lpg burns hotter . and low resistance leads a good idea to . check the website of bosch or NGK for the answers and myths about lpg plugs
    GTP 85's Avatar
    Aug 2006
    Thanks for your help! i only just finishes reading through the tech section on the NGK site
    yea i just got the BPR ones, so i mite jet back to swap them. cheers
  1. plug gaps
    By VYMAD in forum VY Holden Commodore (2002 - 2004)
    Last Post: 19-07-2009, 12:00 AM
  2. spark plug gaps
    By harro_VR in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-11-2007, 05:23 PM
  3. Spark plug gaps and recommended oil
    By VYWORKWAGON in forum VY Holden Commodore (2002 - 2004)
    Last Post: 09-01-2007, 04:58 PM
  4. LS1 spark plug gaps?
    By VTSSDUDE in forum LSx Development and Modification
    Last Post: 24-12-2005, 10:10 PM
  5. Spark Plug Leads Getting 'baked' on to Spark Plugs?
    By holden#1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-09-2005, 04:16 PM
