Hey guys just wondering on the difficulty and price on putting a rb25 or something similar into my series 2 v6 vp???
If i could get some opinions that would be great
Matt
should be easy all u need is a vl k frame and a front cut from a skyline and u will be half way there all u need to modify would be the wiring loom and gearbox mounts
yer easy.
use a VL k frame, and rb30 mounts to get the engine sitting in the bay.
you could use VL power steering rack, pump, bracket etc to get your power steering working (although VL steering feels terrible)
if you're using the manual box, it should bolt right in with a VL MX7 crossmember.
Tailshaft you can use the VL MX7 front half and your VP rear half mated together, for bolt in.
A skyline electronic speedo sender should work with the speedo you already have. (90% sure on this)
The only physical problem you'll have is with the dumpm pipe off the turbo not lining up with the exhaust.
Other than that you will have to wire in a skyline ECU - wouldn't be hard at all.
Best thing about this, is that it's 100% engineerable![]()
