Results 1 to 18 of 18
Thread: VN Brake Test
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Default VN Brake Test
    Took the V8 VN in for a brake test today at the local Repco reps. Stock pads and calipers, VT booster and M/C non abs.
    The car was 1570kgs (full tank 80l) heavy.
    Front: 5087 left, 5350 right
    Rear: 1512 left, 1675 right
    Front to Rear:
    10437 = 76% front
    03187 = 24% rear
    Footbrake peak = 81%
    Footbrake Avg = 75%
    Parkbrake = 21%
    and 3 Dangerous non ABS VN's
    Zuicider is offline Banned
    Set of thongs
    Caribbean Stud Poker Champion!
    Dec 2005
    Stonedville
    bmxj6 is offline vncalaiswagon
    VN Wagon
    Jan 2009
    longford, TASMANIA.
    hi there, am trying to fit vp switch blocks, in a vn wagon, witch has a calais series 3 loom & dash already fitted & was told your the one to talk to, any help would be great. CHEERS.
    VP Executive R-spec
    Jan 2005
    What's this brake test mean, I just want to know how many G's it pulls slowing down
    VP Calais '93
    Mar 2006
    SA- NE BURBS
    Those numbers don't mean much to me mate. Care to shed some light?
    wtb: rockford fosgate sub rfp 3412
    strgas's Avatar
    strgas is offline GRA = REAL HP
    Oct 2009
    88GreenVN's Avatar
    Jun 2006
    This is the VZ:
    Front: 4425 left, 4325 right
    Rear: 2625 left, 2750 right
    Front to Rear:
    08750 = 61% front
    05375 = 39% rear
    Footbrake peak = 83%
    Footbrake Avg = 77%
    Parkbrake = 51%
    88GreenVN's Avatar
    Jun 2006
    Quote Originally Posted by fnlow1 View Post
    It's a special skid plates thing that records the bakes on the car. Bloke drives onto it and brings the car to a stop. Computer spits out the balance between all 4 wheels.
    the numbers are brake force on each wheel in "Newton"
  9. Default
    so the VN has better front brakes than the VZ? amazing! i need to get myself a vt booster and master
    Quote Originally Posted by zai View Post
    I am not sutpid
    88GreenVN's Avatar
    Jun 2006
    Quote Originally Posted by levymetal View Post
    You wont regret it I can tell you
  11. Default
    do you need to change the lines or something, and would that be hard to do?
    I am not sutpid
    88GreenVN's Avatar
    Jun 2006
    Modded booster rod and mount braket. PM Markovr for some ideas/cost. Really is worth the effort and the V8 is a bolt up job as the brake lines are the same (no adapters needed like on the V6)
    VP Exec
    Jun 2005
    Before anyone gets carried away with fitting a new master cylinder or booster it's worth pointing out that neither of these items will improve brake performance. All each of them will do is alter the relationship between the force on the pedal and the force the wheel cylinders apply to the discs i.e. if you can push harder on the pedal you don't need the master or booster.
    You can't say that a VN has better front brakes than a VZ either, only that the front brakes do more work, at least in this test. That stands to reason as the VN (V8) is a smaller car (= likely higher CoG, more effect of engine weight on CoG) with a shorter wheelbase, and a heavier engine. All of these will tend to put more weight on the front wheels as well as cause more dynamic weight transfer.
    Note that the peak and average G's are virtually the same for both cars.
    The most useful thing from the tests would appear to be checking that the brakes are even left to right (they are).
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    we do this brake test every 6moths when we get a WOF done. really it's just to check the ballance.
    Body by Holden, Soul by Brock
    the Legend will live forever
  15. #15
    88GreenVN's Avatar
    Jun 2006
    Well yesterday I had to "test" the brakes for real. I stopped way short of what I thought I was going to. (small car stopped on the yellow in front of me at 60 kph) No skidding or noise from the tyres - but the old VN just about chucked everything out of the boot and over the car.
    All in all I'd still recommend upgrading the booster and m/c even if it's only pedal feel - now I think I need to fix the front shocks
  16. #16
    Apr 2006
    Auckland NZ
    Quote Originally Posted by 88GreenVN View Post
    i've found mine to border on the side of dangerous with the current combo of stock VN V6 rotors/calipers and VT style M/C+booster. it does stop really well unfortunately i have issues with rear wheel lock up when braking real hard. the one time i did have to stop when some old suicidal nanna ran out in front of me i came to a full stop sideways because the rear locked fully and even stalled the engine. the only difference i can see is the manual trans which engine brakes much better then the auto. i'm either going to have to alter my driving style or fit a proportioning valve to reduce rear brake bias. (proportioning valve sounds better)
    no matter what the numbers say. the car pulls up way better then it did before with the standard MC/booster
  17. #17
    88GreenVN's Avatar
    Jun 2006
    Quote Originally Posted by immortality View Post
    Do you have V8 calipers? maybe it's the V8 weight and finned calipers + 225/16 tyres.
    I had no lockup at all and the car just stopped dead - well short of the car in front - to the point of did I over react a little. But no I was impressed no end on my cars brake performance in the dry. Wet may be different tho - we shall see.
  18. #18
    Apr 2006
    Auckland NZ
    nahh mate, stock V6 callipers. i also have fairly new shockers and good 235/45/17's all round
    the fronts did not lock and the car pulled up real good. fact is, if it had happened with the stock brakes the suicidal nanna would have been dead as it would never have stopped in time, as it was i pulled up with probably less then a meter to spare.
    to be honest, the more that i think about it. the more that i think it's related to my driving style/transmission setup. becuase the VN's have such poor brakes i use the transmission a lot to brake. where the nanna stepped out is on my is on my regular route home, it was at the top of the crest of a hill where i normally change down a gear and let the car run down the hill without using the brake pedal. that morning i was in a hurry and had let the engine rev out a little in 2nd coming to the top of the crest ready to change into 3rd to let it run down the hill like i normally do, however the nanna stepped out onto the road without warning and i had to hit brakes hard i think i also popped the clutch out at the same time which caused a compression lock up on the rear wheels and the car going into a slide/spin. some quick fanny footwork on the brake pedal and wheel stopped the back end coming completely around and killing the stupid bitch.
    i'm definitly going to fit VT style rotors and calipers as it will improve the situation again over what i have now
  1. vr brake adaptor sleeve for vt brake upgarde
    By picks in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-08-2009, 12:57 AM
  2. Some door handles & park brake & brake pads.
    By jabsy1 in forum Parts And Other Items For Sale
    Last Post: 07-08-2008, 09:53 PM
  3. Spongy Brake Pedal after VT Brake Upgrade
    By DJ Ice in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-01-2008, 08:48 PM
  4. brake calipers. loss of brake power
    By VN-88 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-02-2006, 11:55 PM
  5. Leaking Master Brake Cylinder Connecting to Brake Booster Advice help please.
    By IceDHB in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-08-2005, 02:32 PM
