Results 1 to 4 of 4
Thread: connecting rod removing
    88 VN 5spd 3.8
    Apr 2007
    Corio,Victoria (Geehole)
    Default connecting rod removing
    hey peoples can someone help me and explain the easiest way to remove the connecting rod from piston, im rebuilding my 3.8 and have to use my old connecting rods for new pistons but cant work out how to get'em off im use to working on little pistons that have a circlip holding them these dont so ant input would be great thanks
    Project_HR's Avatar
    Project_HR is offline Budget Buster
    VL V6 Turbo'd Sedan, Turbo'd V6 Altered
    Apr 2008
    Noo Zilland
    Quote Originally Posted by the executive View Post
    Yeah, you need a press to push them out, as they are an interferance fit in the rod. Sometimes you can get away with it in a vice, if it is big enough, but it is clumsy that way. You need to support the piston, have something slightly smaller than the pin to push with, yet have a hole underneath for the pin to pass through. I would ask a local garage if you don't have a press, might cost $20, but will save a lot of grief. Good luck
    Turbo's give cars their best ever blowjobs !!!
    88 VN 5spd 3.8
    Apr 2007
    thought as much cheers mate i'll drop'em off at the re conditioner where mi blocks gettin bored on monday ill get them to do it
    Pub247's Avatar
    Pub247 is offline Donating Member
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    Yeah best to get a reco to do it theyll have something that supports it better to push them out
    Quote Originally Posted by Smidy
    How many kw would i need to beat vin diesil to the train lines?
  1. Connecting Rod Bolts
    By timgamble74 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-03-2009, 01:15 PM
  2. Connecting a VAC gauge to 3.8
    By TapouT in forum VY Holden Commodore (2002 - 2004)
    Last Post: 07-02-2009, 12:15 AM
  3. connecting strereo in a 97 vs?
    By samboi17 in forum Car Audio
    Last Post: 31-07-2008, 08:06 PM
  4. Connecting Fog Lights on a VT S
    By nabed4t in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-04-2008, 06:41 PM
  5. Dis-connecting immobiliser
    By Just_Ice in forum Electrical Wiring / Questions
    Last Post: 19-02-2006, 06:41 AM
