Results 1 to 10 of 10
Thread: V8 conversion help..
    vp commodore interceptor
    Oct 2009
    Default V8 conversion help..
    Hey ive just finished a v8 conversion to my vp when i went to start it i found the fuel pump is now..not working.I checked all wiring,fuses,relays and there all good.I have a auto elec coming tuesday but if i could fix it myself it would be good.Any ideas of what else i could try would be really helpfull. Thanks
    VP Executive R-spec
    Jan 2005
    Oct 2009
    Quote Originally Posted by greenfoam View Post
    immobiliser switch buggered?
    There was no immobiliser on it, thats the same thing my brother said. Cheers for your help anyway.
    pow3rslave's Avatar
    pow3rslave is offline DoNothing Member
    VP 5.0L
    Oct 2005
    eastern subs, vic
    Oct 2009
    Quote Originally Posted by pow3rslave View Post
    what engine/box did you put in and what box did it have to start with?
    I put a vn ss motor and box in(AUTO),and it had just the normal t700 before that.
    pow3rslave's Avatar
    VP 5.0L
    Oct 2005
    eastern subs, vic
    i think some vn v8's ran two pumps. not sure, but it could be something to look at.
    Renno's Avatar
    Renno is offline Home Of The Shiny Tank
    VN Calais 5L
    Dec 2008
    Defected And In The Shed
    VN V8's did run a twin pump setup. However the external pumps wiring was piggy backed off the internal pumps.
    I converted my VN stock twin pump setup in my 5L to a single pump VR SS sender unit with walbro pump and it all plugged in to the factory wiring loom and worked.
    VP Executive R-spec
    Jan 2005
    VX S SuperCharged
    May 2008
    Have you tried hooking the pump straight up to your battery to see that the pump itself hasn't died?
    Oct 2009
    Unhappy
    Quote Originally Posted by Sheany View Post
    No i havnt tried that i was guessing the pump would still be right cause it was working perfect when i had the 6 in it. I will try it anyway thanks Sheany. (Greanfoam im 100% there is no imobiliser on this car.Thanks)
    (Cheers reno i might have to look into it if the auto elec doesnt sort it out today.)
  1. Man conversion-cruise control, will the auto cruise control work on manual conversion
    By pjdm1980 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-08-2009, 12:25 PM
  2. Gas conversion
    By cart in forum VY Holden Commodore (2002 - 2004)
    Last Post: 04-07-2008, 08:35 PM
  3. conversion people conversion
    By flynn84 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-09-2007, 01:25 PM
  4. Help with Conversion
    By MrVK85 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 03-10-2006, 03:06 PM
  5. Vp manual conversion and vn auto conversion
    By gumbs in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-06-2005, 11:08 PM
