Firstly i apolagise if it's been covered before, if it has could you please link me to the thread.
Otherwise, how hard is it, and what is needed to swap the switchblocks over, on VP exec, to those found in a Calais/Statesman ect.
You might find some of the buttons dont have the same action ...like the heated rear window on some statos use a momentary action instead of a push on push off type and the dimmer works different too and the int wipers have different controls too as they use a bcm and the exects dont have a bcm.
This is my vr that I rebuilt ....CLICK HERE to see my vr on Cardomain ......if you want to check it out......Anyway make sure you rubbish a ford daily ....I am a 4DH8RZ Club lifetime member .................new members joining everyday
there is a difference between vn and vp in this case. i'm going to be naughty and assume that a vq would run the vn style, unless it runs a different setup again . some of the buttons are switched around, and the vn style uses more (as above) push on / push off buttons, while the vp uses a lot of momentary action ones (so, an electronic switch).
