Results 1 to 4 of 4
Thread: vq 5L trans probs
    vq statesman 5L
    Oct 2009
    Default vq 5L trans probs
    i have a 5L vq sometimes when i hop in the car drives sweet as, other times when i hop in it doesn't want to change gears waiting till about 4500rpm before it changes and thats taking it real easy, if this happens i pull over then turn the car off then on and the trans starts working properly, i have a feeling it is an electrical problem, any ideas???
  2. Default
    it won't be electrical - your transmission is manually controlled by the kickdown cable which is located on the throttle body.
    2 possible problems:
    1. stuffed transmission
    2. sticky kickdown cable. when it starts happening, check the kickdown cable on the throttle body to ensure it is retracting with the throttle.
    here's a photo for reference
    Quote Originally Posted by zai View Post
    I am not sutpid
    vq statesman 5L
    Oct 2009
    the kick down cable seems to be retracting ok, i dont see how it could be a stuffed trans when it works fine after i turn the car off then back on, maybe just needs servicing?
  4. Default
    well, are you 100% sure it's the turning off / back on that actually fixes the problem? maybe it's the shifting from drive to park and back to drive that fixes it. either way it's not electrical because the box has nothing to do with the computer. i would definitely get it serviced if it's been a while though, some peoples transmission problems go away after a service
    I am not sutpid
  1. trans probs
    By teote1 in forum Just Commodores Polls
    Last Post: 26-02-2009, 02:09 AM
  2. V8 trans probs
    By undar8ed1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-12-2008, 02:50 PM
  3. Auto Trans problem when hot - need a trans cooler ??
    By woteva in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-12-2007, 11:41 PM
  4. VS II V6 Missing and trans cooler probs
    By nick88 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-01-2007, 06:42 PM
  5. vr trans (not the standard probs but, i need help)
    By WILD VR CLUBBY in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-10-2006, 10:29 PM
