G'day all
I'am rebulding my motor and i cant get the crankshaft pully off it's been a right ****.HELP ME BEFORE![]()
Are you replacing the balancer or wishing to reuse it
OK what model is the engine out of ?
ok the balancer should have three slots in it close to the bolt head this is where the puller tool hooks in but if you dont have that then cut the rubber from the inner hub to the outer hub off then you can use a three jaw puller to remove it
