Results 1 to 15 of 15
Thread: uber hot key in vp
    Zuicider is offline Banned
    Set of thongs
    Caribbean Stud Poker Champion!
    Dec 2005
    Stonedville
    Default uber hot key in vp
    Mates vp wagon, after a short trip the key in the barrel gets bloody hot. any ideas?
    TVR-190's Avatar
    TVR-190 is offline SkyFall
    WK Statesman LS1
    Jun 2008
    Sutherland Shire N.S.W
    Set of thongs
    Dec 2005
    Stonedville
    TVR-190's Avatar
    WK Statesman LS1
    Jun 2008
    does his have the illumination light under the key barrel. possibly the globe heating the barrel and key up
    The Black Beauty
    Set of thongs
    Dec 2005
    Stonedville
    Set of thongs
    Dec 2005
    Stonedville
  7. Default
    sometimes when i pull the key out of the ignition it seems hotter than a key should be. never worried about it though, seems like a common problem
    Quote Originally Posted by zai View Post
    I am not sutpid
    Set of thongs
    Dec 2005
    Stonedville
    STEALTHY™'s Avatar
    STEALTHY™ is online now So Wet For You!
    VP Calais International, VP Berlina LX Wagon
    Jan 2005
    SA - The Roadworks State
    Just get a standard GM key cut with the plastic.
    Quote Originally Posted by davway
    Improved Suspension Reduces Handling!
    Quote Originally Posted by JONNNNOOOOO!!
    cheers sexy
    Set of thongs
    Dec 2005
    Stonedville
    VXII
    Nov 2009
    High resistance across the switch contacts causes the heat buildup. Common problem. I've seen it melt the plastic before. Replace the switch and wires part of the ignition barrel, but don't bother with a second hand one, it'll probably do the same thing.
    Set of thongs
    Dec 2005
    Stonedville
    Quote Originally Posted by moose man View Post
    well i have about 5 spares so its cheaper to give them a whirl
    1990 VN Executive
    Nov 2005
    Well this is a first for me in 24 years as a Locksmith, a hot key
    Dazz
    VN BT1 Mock Up Commodore
    Dynamic Locksmiths
    Set of thongs
    Dec 2005
    Stonedville
    Quote Originally Posted by bj42turbo View Post
    Dazz
    wouldnt that be a flathead screw driver?
  15. Default
    Quote Originally Posted by STEALTHY™ View Post
    i bought one just never got around to getting it cut
    I am not sutpid
