Results 1 to 4 of 4
Thread: vn 5lt rear main seal
    vn ss
    Sep 2005
    Default vn 5lt rear main seal
    can any one tell me how hard it is to change rear main seal on vn 5lt ss commodore
    VQ Caprice
    Apr 2009
    Castlemaine
    im no mechanic but here goes.you have to undo the trans bolts pull the trans away from the motor as much as you can then carefuly remove old seal with flat screw driver put some ultra blue on the new one push it in so it goes in square.does that sound about right to anyone ?
    VP Exec
    Jun 2005
    That'd be correct for a post s2 V6 but the 5L has a rope type seal => drop the sump, pull the trans., front cover and drop the crank. An alternative is to drop the sump only and use a "Sneaky Pete" tool to pull the seal around in the groove in the block.
    The question has been asked before so you should find some more with a search.
    Warranty Void's Avatar
    Warranty Void is offline Take it apart? Me? No!
    VP Berlina LX V8
    Sep 2009
    I'm doing the same thing and asking similar questions, check out
    Rear main seal on 5.0 V8
    If it's a rope seal (Most likely it is rope) then it requires the crank to be dropped down a bit to fit the top seal. You may get away with only removing the gearbox if it's a poly seal but you'll still have to drop the end bearing cap. I'm reliably informed that the injected 5.0 has rope seals up until the series 2 VP.
    Warranty Void
  1. Rear Main oil seal AGAIN
    By LisnM8 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-07-2008, 05:48 PM
  2. Rear Main Seal
    By Slow VR in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-03-2007, 10:01 PM
  3. vn s1 rear main seal
    By shyvn6 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-06-2006, 07:28 PM
  4. Rear main seal
    By mouce in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-05-2006, 03:45 AM
  5. rear main seal
    By markovr in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-07-2005, 02:38 AM
