there's 3 plugs near the battery/fuses. one of them is clear/white and has 5 wires in each side. can someone tell me where the purple wire on the engine side of the plug goes to? the purple on the fusebox side of the plug just seems to go to earth, but i think i've hooked mine up wrong on my conversion which means something won't be earthing right.
just had a quick look and I think it goes to the coil pack but its a bit hard to see as its very f-----n dirty
Maybe fuel pump? Is it at the outside of the 5 pin connector? If it is that wire it comes from the fuel pump fuse into the fuel pump relay and out to the five pin connector. There is a splice off to the ALDL connector and the wire also goes to the oil pressure switch and to the ECM.
