Results 1 to 10 of 10
Thread: engine noise!!!!
    1 Immac VN Commodore
    Jul 2005
    Default engine noise!!!!
    Hi ive got a vn v6 series 2 motor its got 250,000k on it. recently its developed a rattle/nock type of nosie at the front part of the motor. ive taken off the belt and noise goes away, could it be the harmonic balancer or something behind the timing cover.wondering if anyone has had similar problem out there. THANKS [SIK-GMH]
    Garth's Avatar
    Garth is offline Your guess is as good as mine......
    not telling
    Space Invaders Champion!
    Oct 2002
    nice and easy, harmonic ballancer, be sure to make sure you get the right ballancer, runs of the build date, and weather it's a series 1 or 2, simple job to replace also
    cheers
    garth
    i am the god of britany spears womanizer on just dance on the wii
    94 vr 5sp, 04 vz wagon,82 vh efi wagon,88 vn 5sp
    Nov 2003
    northside brisbane
    If its the balancer you should see the rubber between the inner and outer parts fractured.If you look from the front of the balancer you should be able to see it but you might need a mirror to see it.
    The noise is not anything behind the timing case if the noise goes away when you take the belt off.
    Check the water pump bearings if the balancer looks ok and then the tensioner.
    This is my vr that I rebuilt ....CLICK HERE to see my vr on Cardomain ......if you want to check it out......Anyway make sure you rubbish a ford daily ....I am a 4DH8RZ Club lifetime member .................new members joining everyday
    Jul 2005
    thanks for that ill check it out it hopefully i can fix the problem because its a real head turner(noisy idle) :b: lol thanks for the replies cheers!!
    nickiscoollest Guest
    depending on the sound it could be simpler again with the tensioner pulley bearing being worn. thats a 30$ replacement part from repco but be carful not to get one of the ones that was recalled (i got 4) before gettting one that worked well free of charge of course
    Majesticknights's Avatar
    Majesticknights is offline The Dark Prince
    VL HDT Calais Wagon Brock 346 stroker
    Jun 2005
    Montrose, Vic
    my gf mother got a similar bad noise in her mazda, turned out to be he clutch on the aircon pump. check out all thing that run off the belt before running out and buying stuff or atleast keep ur receipts
    VX SS
    Oct 2004
    Mandurah W.A
    i hate that tapping noise.. harmonic balancer.. its so easy to recognise.. sounds like marble or something thrown against a wall.. but always make sure u know wat it is before u go spending cash
    Wonderboy Guest
    tensioner pulley bearings is common. if u dont have a mechanics stethoscope, u can use a long screwdriver and place it on the bolt that holds the pulley on with the engine running u press your ear hard into the end of the screw driver handle and it will amplify any bearing sounds through the handle so its easy and loud to hear. u can use it on any engine part. and all the pulleys and the harmonic balancer. even stuff like rocker covers. auto housings. diffs u name it. i have a stethoscope and its much more comfy than a screwdriver but it does the job
    kirkson is offline Captain
    93 vr v6 exec duel fuel
    Oct 2005
    I would remove the fan belt. and spin every pully by hand you will definately hear the offending one, I will put my money on your ideler bearing easy peasy, just remember it has a left hand thread.
    regards Kirk
    Captain
    VT Berlina wagon 5.0 litre
    Jan 2006
    ive got a 5.0 litre V8 VT and it has the same noise.
    i changed the idler pulley and it is still making the noise.
    i did the trick with the screw driver and put it to the water pump and it was noisy as hell.
    is it hard to change the water pump on a 5 litre?
  1. engine noise
    By reg9128 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-01-2007, 05:45 PM
  2. Help with engine noise
    By vl8 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 13-02-2006, 12:33 AM
  3. engine noise
    By bundyman85 in forum V8 Development and Modification
    Last Post: 23-12-2005, 04:03 PM
  4. engine noise. need help
    By matrix in forum Car Audio
    Last Post: 15-11-2005, 11:06 PM
  5. Engine Noise....
    By stheggie in forum Car Audio
    Last Post: 30-04-2005, 12:39 AM
