ive done it before but im hopeless at step by step instruction
1 make sure you have very little fuel
2 undo 3 (i think) bolts at front of tank
3 slowly and carefully pull every thing out this can take some twisting and turning
4 fuel pump is at the end of all this disconnect and replace
5 reverse process to put back in
hope this is some kind of help hardest part i found was lining the plate back up to the tank to put the bolts back in other than that very easy process
If its got Wheels or Boobs its gonna cost ya money
