My vn has been doing the same as many, sometimes not starting when hot, or dying after a while and then unstartable until it cools down (or maybe its the wire wiggling I do while waiting).
I have seen many options here and will test the CAS tomorrow. But all the posts relating to the CAS seem to say things about the engine running badly. Mine is running perfectly then just cuts out. No spluttering or loss of power. Its either on or its off?
Is this consistent with a CAS fault?
also I have tried to get an error code but I can't seem to find a 6 pin block, the only block with a black and white wire under my glove box is a five pin and the male has wider connectors than pictures Ive seen of in on the net..
Im learning alot and have many things to check in the morning...
