Finnaly got around to putting my Grange 18's on and the Hsv center caps dont fit!!!! there dont fit because of the bearing covers!
How do i get around this?
also the tryes on the rims are 235/40/18's and are only just clearing the front struts, 5mm maybe.
should i conside 225's?
2 Options, you could put VR Hub assemblies on (not sure how this works with non ABS, as everytime i've seen the conversion it was on a VP with ABS)
Or you can do what i did, and get custom centres made, that fit over the hub assemblies. Theres a guy in SA i could put you onto who already has the exact measurements, so it would be a fairly simple task to make another set up and post to you.
Originally Posted by davway
could just buy the actual HSV sticker bit that goes on the centre cap and glue it onto your wheel. dunno how long it will stay there for
1995 Manual HSV Clubsport
1991 Supercharged VN Berlina
so in other words the set of caps i have here are useless? dammit!!!! nothings ever easy!!!
so stealhty what did this guy charge for ur custome caps? do u have to send him a set for him to modify or does he do them from scrtach?
There made from scratch out of aluminium. Not sure what he's going to sell them for, so you'd have to email him to ask how much they are.
Growly Custom Machining
vr hubs will need vr struts too.i have the same problem with my spare wheel centre doesnt fit as they are off VR onwards
ok the vr strut idea sounds like way to much work. and really the sticker thing wont work there is nothing to stick it to. i guess the only option i have is get some made up. ill email the bloke now. are the backs the same? or will the caps fit?
I'm not sure what you mean by 'are the backs the same'.
All 4 caps will be made identical, so even if you rotate your wheels, all the covers will still clear the dust covers. Also, you can get any design you want engraved onto them, or just have them flat (and stick the HSV stickers to them like stocky said)
Heres what mine are
Been covered before. I have them on mine all you need to do is sand the ridges back on the center caps and knock the dust cover back slightly, clears fine.
your caps look mint stealthy!
so i can use normal hsv caps i just have to sand the ridges down on the backs? and knock the dust covers on a bit more?
Ok you can do this in 5 mins its easy as pie, i did this when i put on ve calais wheels onto my VN.. and the centre caps on the front are Perfecto.
Take off the dust cap, and use a hack saw to cut away one level of thread, use a file to tidy up the rough edges. then clean up the dust cap in a bit of petrol so you dont make a mess for this bit. Take the cap and gently using a hammer, flatten the face of the cap so that it wont buldge the cap out.
Replace the cap and your done,
Thanks AussiePhonieox, i will pull the covers off give them a bit of modifying. Will keep everyone posted with how i go. Goimg to Melbourne tomorrow to pick up my VQ dash but after that ill see what i come up with. Thank you all so much.
would ther be a spacer available that would space out the rim just enough for the cap to clear the bearing cover?.. my 18" hsv rims on ma vn need about 5mm for the centre caps to fit, i tried taking off the bearing cover and fitting the caps and they still wouldnt fit.
ok ive finally got my 4th wheel done in proper shadow chrome and new tyres. I need to get these caps on, so sand the ridges and try them then?
Then if not knock face of cover in? and cut a thread off?
I need to get these on!!
