Results 1 to 14 of 14
Thread: crank stiffness
    88 VN 5spd 3.8
    Apr 2007
    Corio,Victoria (Geehole)
    Default crank stiffness
    hey guys i'm in the middle of rebuilding my 3.8 and just want to know if its normal for crank to be really tight after installin new bearings and seals? any other info or advice would be appreciated oh and just to add yes i did fill journals with oil upon installing also if any1 from geelong has a ring compressor or sucky stick to grind my valve i can borrow for the day let me know please cheers
    Reaper's Avatar
    Reaper is offline Tells it like it is.
    E3 Senator Manual, VP SS
    Aug 2004
    It should rotate smoothly. If it's grabbing or particularly stiff something is wrong. Did you re-size the bearings or something?
    Ring compressors are around $15 from autobarn. Not going to last forever but should hold together for a few engine rebuilds.
    Reaper
    Reapers Black VP SS
    0-60 mph = 5.39 Sec, 2.30 60'
    Quote Originally Posted by skruba View Post
    practice makes perfect dude i was (still am) my bros guinea pig,he has been tattooing for near 2 years.
    VN Berlina 2L
    Oct 2008
    Does it have all the pistons on? You should use plasti-guage to measure the clearance between the bearing and journal. Have you used micrometers and straight edge/feeler gauge to measure your journals and crank bearings?
    strgas's Avatar
    strgas is offline GRA = REAL HP
    Oct 2009
    it should be tight to a point that you dont need a six foot pole to turn it over , a good push on a sidchrome ratchet and socket should be all you need .. did the bearings come cover in rust preventive coating or a sealed bag .. seen acouple of guys install the bearing with the coating still on them and the engine didnt rotate to well at all , did you use a rope seal for the rear main ???
    Sabbath''s Avatar
    Sabbath' is offline Take it out/Take it Back
    Turbo Diesel SR5 Hilux/VH 308
    Jul 2006
    88 VN 5spd 3.8
    Apr 2007
    everthing was done by the wat book says bearings are standard and came in plastic wrap with my acl kit, i bought the tools i needed from repco they had'em on special, can rotate crank by hand but it is pretty tight
    88 VN 5spd 3.8
    Apr 2007
    Pub247's Avatar
    Pub247 is offline Donating Member
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    did you soak the seal before install?? ropewill be tighter than a neoprene one but it should turn by hand easy
    as said above are the caps in right order and around the right way?
    Did you check your end float is right??
    was the crank linished before install?
    Quote Originally Posted by Smidy
    How many kw would i need to beat vin diesil to the train lines?
    88 VN 5spd 3.8
    Apr 2007
    rope seal didnt get oil, everything else seems ok. bearings do have a grey coating which i didnt clean off
    VP Executive R-spec
    Jan 2005
    Was the backside of the bearings clean without oil?, that's enough to make them too tight
    88 VN 5spd 3.8
    Apr 2007
    well i removed all caps and bearings oiled rope seal, cleaned all bearings and removed coating its not as tight now i can actually rotate it with 1 finger on the rachet still with abit of force but before it was 2 finger and a heap of force so it is better hopefully good enough...
    Pub247's Avatar
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    yep sounds alright now. i hope you atleast put some oil or moly grease between bearings and crank
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    when you say you removed the grey coating you dont mean the soft metal that protects the crank do you LOL the bearings are meant to be gray
    VN Production Saloon
    Mar 2009
    Gisborne NZ
    Quote Originally Posted by Pub247 View Post
    In full agreement there, the dog turd style rear main seals are a lot tighter than the neoprene one peice jobbies, i always dummy up the crank without the seal first to see how it spins to pick up on any misalignment of the tunnels or twist in the crank then pull it out again and fit the seal.
    COOK COUNTY PERFORMANCE porting heads/manifolds & blueprinting. tuning by DELCOWIZZID
    WANTED SV3800 headers for 34G, need stockers as made by HM headers ~ used with patina prefferable for scrutineering
  1. 304 crank
    By v8_bomberdore in forum V8 Development and Modification
    Last Post: 05-06-2009, 11:47 PM
  2. vn crank?
    By kane88 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-05-2009, 08:33 PM
  3. crank?
    By esaad in forum V8 Development and Modification
    Last Post: 29-04-2009, 06:52 PM
  4. Which crank do i have in my Vn
    By futronix in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-04-2009, 06:55 PM
  5. L67 Crank
    By ADZ124 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-04-2006, 05:49 PM
