g'day i got a prob (hopefully electrical) the VN i have just brought i took out the front to clean the enginethe motor was running fine but after i had washed the motor the car oil light came on so i stopped the car went to start it again no power i had to wiggle the termanil to get power back now the oil light stays on i hope it is just electrical but i dont want to take the risk.
So how can i cheak the electrics or see that the pump is working properly???
PLEASE HELP!!
Sounds like you just got water in the plug, its common, but if you wanted you could check the Error codes, it will tell you what sensors are on there way out if any, but it just seems to me water got in the connection.
~ VN POWER ~ Click the scales
