Results 1 to 11 of 11
Thread: Wont Start, Error Codes
    Ke30 Rolla'
    Oct 2009
    RAD-elaide
    Unhappy Wont Start, Error Codes
    Dont you just hate cars somedays ?
    went out to start my animal, and nooo, she dosent want to run, cranks over, idels for 3-4 seconds, then drops revs, and dies
    so i decided to check the error codes, Sweet numbers 44, 45 appeared
    Code 44 - Oxygen Sensor Lean (O2)
    Code 45 - Oxygen Sensor Rich (O2)
    so i unclipped the Oxy sensor, from the extractors, and the car started fine , idled for 10 seconds, then died again, :'(
    i then reset the computer, and checked the codes again Sweet number 12 all fine ?
    yet it still wont idle for over 3 seconds, before dieing
    any suggestions ?
    VN Commodore
    Mar 2009
    what happeneds when you rev it and hold the throttle? i would start by changing that O2 sensor.
    Ke30 Rolla'
    Oct 2009
    RAD-elaide
    if you rev it and keep it over 1k RPM, it will sit there, but as soon as ur foot comes off the accelerator it dies D:
    Ke30 Rolla'
    Oct 2009
    RAD-elaide
    Ke30 Rolla'
    Oct 2009
    RAD-elaide
    little bit of an update, after 10 seconds of cranking over, i can get it to idle, but as soon as the foot touches the accelerator, u can hear the TB sucking air in. like a pod filter, then the car drops in revs and dies :'(
    Ke30 Rolla'
    Oct 2009
    RAD-elaide
    Ke30 Rolla'
    Oct 2009
    RAD-elaide
    VS 96 Exec Wagon
    Jul 2009
    Queensland
    IAC may need reset/replace/clean ?
    Paintball.. It's not just a Sport.. It's a lifestyle!
    Check out my VS Wagon !
    See my Re-Mixes here YouTube - Dtek5
    Black VN MANUAL
    Feb 2007
    Top of Vic
    If i where you i would just replace the O2 sensor with another, or buy a new one, just because you reset the computer that just wipes all the codes, but the sensor sounds stuffed to me, and will still be causing the problem, but clean out the T/B aswell cant hurt.
    ~ VN POWER ~ Click the scales
    VN Commodore
    Mar 2009
    i had a similar problem where i could get it to idol but as soon as i gave it gas it died. Turned out to be Fuel, i ran the tank to empty filled it up then this started. It was a blocked fule fliter, i replaced it and ran a bottle of injector cleaner with the next tank and it all runs fine now.
    Ke30 Rolla'
    Oct 2009
    RAD-elaide
    got the step dad, to call out RAA for free because he was a member, he said he was driving the car and it just wouldnt start, , turns out it was faulty fuel in the lines, and a fuel filter , the animal is running again
    but somehow the battery is dead now ....
  1. 'fuel gage error' displayed, ute wont start
    By mickey007 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 26-10-2010, 05:04 PM
  2. VZ Fuel Guage Error - Wont Start - Conclusion
    By bigdaddycool in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 21-09-2009, 10:15 PM
  3. VY trouble codes/error codes. NEED HELP!!
    By GILLO in forum VY Holden Commodore (2002 - 2004)
    Last Post: 16-03-2009, 04:04 PM
  4. PLEASE HELP! VR wont start error code 48
    By ecotec_powa in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-02-2008, 05:45 PM
  5. Error codes 47 and 49.....uterus wont run
    By bundysmurf in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-09-2006, 05:24 PM
