Hey guys,
Yeah I know another agh start ya basterd thread.
Car is: mums 93 vp v6 auto
Problem: hard to start somtimes, but every time you start it in the last week, it starts running real rough then idels to 2grand for about 15secs then drops down to about 1grand.... I've tried a new CAS and not long ago replaced fuel pump. Was thinking maybe DFI but its only on start... have checked all lines for vac leaks and earths. Only had a few hours tonight to have a look for her.
Also (saves starting a new thread) 93 vr will motor and box fit vp? What other parts fit??
Jay
I would be Leaning towards the IAC (Ideal Air Controll), its on the Throttle body, that controlls the idle RPM if could need a good clean, you should try cleaning the T/B out with T/B cleaner, also if the engine light has came on as some stage you should check the Error codes to see what sensors have came up, but i would start with cleaning the sensor out.
The VR motor will bolt up but the auto is electronic not cable, so the motor is a clean swap considering it should be the same as whats in your car atm.
~ VN POWER ~ Click the scales
I didn't think the first vr's had electric gearboxes?
As for error codes there coming up with fine. I did clean the throttle body about 2 weeks before this started happining. Maybe this has somthing to do with the problem
i have a vr motor and 5speed box in my 93 vp!
I have a rebult motor in my VN s1 out of a VR manual ute and im having the same starting problem, ill try a new IAC sensor and see what hapends I have already cleaned out the TB and the IAC sensor with no luck.
Check the fuel pressure regulator. Pull the vacuum line off it and see if it has fuel in it.
