Results 1 to 8 of 8
Thread: Engine knock????
    padrickz88's Avatar
    padrickz88 is offline Rick =]
    VN V6, nothing special
    Dec 2005
    sunshine, melbourne
    Default Engine knock????
    Hi people, need some advice on what people think this might be..
    WELL last night I went for a drive, about 60km and 50km of that was freeway, nice easy driving.... 3000rpm changes max....
    Park out the front of my mates place and turned the car off for about 5-10 minutes then when I went to re start it, I had a knocking noise in the engine (as soon as it turned over the noise started) SO I turned it off and started it a couple hours later to go home and was even worse and pretty damn loud then as I was about to drive away the oil pressure light came on for not even a second then the light turned off, and stayed off.
    So I started driving home and when revving over about 1500 the knock was pretty much non existant....
    Car drove exactly the same as it usually does, no lack of performance just a hard knocking noise when below about 1500-1750 rpm
    It was idling fine, just loud.....
    So does anyone have any idea what the problem could be? Got me stumped, usually I read threads about it getting louder with revs, not disapearing :S
    Thats my story, any help and suggestions would be appreciated
    strgas's Avatar
    strgas is offline GRA = REAL HP
    Oct 2009
    When did you last change your oil and filter and what grade of oil are you running ....
    padrickz88's Avatar
    Dec 2005
    sunshine, melbourne
    Changed oil and filter about 5,000k's ago and currently using a 15-40....
    strgas's Avatar
    Oct 2009
    i would check your oil pressure with a gauge to confirm what pressure it has , it could be a lifter problem or maybe a oil pressure relief valve stuck open to a worn bearing start with the basic's , maybe even spin on a new filter ...
    nil
    Dec 2009
    Yeah as strgas said, check your oil pressure with a 'master' guage, if it was lifters it would get louder with engine rev's. The oil light coming on for a second could indicate a slight blockage, how often do you replace oil/filter and whats your driving style? Long trips only, short trips? bit of both? start/stopping?
    padrickz88's Avatar
    Dec 2005
    sunshine, melbourne
    Sweet ill give it a look, will give me something to do tomorrow........
    The car usually drives a bit of everything, so yeah........ The thing is its not a tick its actually a knock/clunking noise and goes away any revs over 1500.....
    Thats what has me confused because if it was a blockage wouldn't it always do that no matter what rpm? (guessing)
    VR, VX, VN Commodore's
    Dec 2008
    that sounded exactly like what happened to my VR, was big end bearing
    Dont Take Life Too Seriously, You Never Get Out Alive Anyways.
    2002 Series II VX SS - 6spd - 5.7L - Black - Red Leather <3
    padrickz88's Avatar
    Dec 2005
    sunshine, melbourne
    WELL! thank god it was nothing bearing or oil related...... was just a stuffed harmonic balancer (the inner part seperated from the outer section)
    But i think i might do an oil flush next service just incase
    Thanks for the help
  1. Engine knock
    By MG's VH Wag in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-03-2009, 08:50 AM
  2. Knock in the engine
    By IvegotaCommy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-10-2007, 11:20 AM
  3. Engine Knock
    By BeastVS in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-08-2006, 09:47 PM
  4. knock in engine
    By stockvp in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-02-2006, 09:06 PM
  5. Engine Knock :(
    By motorozer in forum VY Holden Commodore (2002 - 2004)
    Last Post: 12-04-2004, 12:53 PM
