Results 1 to 2 of 2
Thread: diff bushes??
    millaz88's Avatar
    millaz88 is offline wishin me v6 was blown :)
    vn commodore
    Sep 2009
    gippsland
    Default diff bushes??
    how hard it it to replace the diff housing bushes do i need to take it somewhere with a press? or can it be done in my shed?
    strgas's Avatar
    strgas is offline GRA = REAL HP
    Oct 2009
    If you have the tools required to remove and refit on car it easy as .
    easy to remove the bushes with the use of a air hammer by crushing the bushes behind where they fit in as these are a tapered bush take care to remove in the correct direction note the position of the bush in the bracket . to install the bush you need a suitable press tool or puller and a spacer to fit between the bracket to stop the bracket from crushing in when force is applied to fit the new bushes..
  1. Z-Bar Bushes
    By Stimps in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-01-2009, 03:42 AM
  2. Caster bar bushes and rear cross member bushes
    By Galixia in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-06-2008, 08:32 PM
  3. bushes
    By Matty o in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-04-2008, 08:47 PM
  4. Z-Arm bushes
    By VN_Luke in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-05-2006, 01:11 PM
  5. Z bar bushes or Radius Rod bushes?
    By Shounak in forum General
    Last Post: 12-04-2006, 05:29 PM
