Results 1 to 4 of 4
Thread: help!! how to remove front springs from struts VN
    vl turbo (in the build)vn 5spd turbo daily
    Jun 2009
    Default help!! how to remove front springs from struts VN
    hi guys have just removed my front struts on my 89 vn to fit some lower springs.. i have just undone the big bolt at the top of the strut that holds the metal plate on top of the spring, but i still cant get the spring off the strut any help would b great thanks
  2. #3
    nil
    Dec 2009
    BEFORE you remove the big nut on the top of the strut, you have to compress the coil spring with spring compressors like levymetal mentioned. One on each side. Compress the spring until you can move it, then remove the big nut on top. If the whole shaft turns, there should be a square section on the top of the shaft to hold it with.
    Depending on the crap thats built up around the base of the spring, and how long it's been on there, it may be a bit tight to get off. Just pry a screw driver under the bottom of it and it should come.
    Make sure to fit everything in the order it came off, and the correct direction.
  3. #4
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    If the spring isn't compressed the tension could be locking the plate against the strut shaft.
    Be very careful, put the nut back on a few turns then compress the spring.
    Visit my Facebook page
  1. [SA] WTB VN Front Struts and springs
    By Vr929 in forum Swap / Wanted to Buy / Trade
    Last Post: 14-07-2009, 06:22 PM
  2. changing front struts/springs
    By somerandom in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-04-2009, 11:05 AM
  3. will springs from VN, VP, VR&VT fit VS front struts?
    By tom790 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-02-2009, 10:52 PM
  4. Front King Springs and Struts
    By johnvtls1 in forum Parts And Other Items For Sale
    Last Post: 09-07-2008, 06:27 PM
  5. FS: Whole Suspension Setup (Springs , Shocks, Struts) King Springs
    By ssmate in forum Parts And Other Items For Sale
    Last Post: 01-11-2007, 06:24 PM
