Results 1 to 9 of 9
Thread: What is this called? vn/vq interior
    VN S Manual
    Jul 2009
    Default What is this called? vn/vq interior
    Im in the process of doing a vq dash into my vn and i have hit a few problems.
    First i damaged the windscreen panel that covers the main mounting locations on my vn dash, was already cracked before i got to it though.
    now on my vq dash im putting in i have no panel at the monment. what is this plastic windscreen dash panel called, how do u remove it from the dash and are they the same across vn vp vq?
    second the vq dash came with no speaker grills and my vn ones dont fit. do only vq ones fit or do vp also? where can i find some, and how much would i be looking at?
  2. Default
    hmm. are you talking about the dash surround that houses the buttons, or the clear plastic lens covering the cluster? to remove the surround there are 4 screws that you access from underneath. it's pretty self explanatory once you do it. then unscrew the cluster and take that out. with the dash out, it's also pretty self explanatory to take the lens off.
    i am surprised that the speaker grills don't fit because i thought a vq dash was the same a vn one. could be wrong though. wreckers would be a fantastic place to start
    Quote Originally Posted by zai View Post
    I am not sutpid
    STEALTHY™'s Avatar
    STEALTHY™ is online now So Wet For You!
    VP Calais International, VP Berlina LX Wagon
    Jan 2005
    SA - The Roadworks State
    Like levy said, speaker grills should fit, all the dashs are identical, only the colour changes (or strips added). You have to twist them sideways to get them in properly (and this is how you get them out without breaking them).
    If your talking about the leanse covering the cluster, theres just 3 screws along the bottom, and 2 'clips' on the top.
    Quote Originally Posted by davway
    Improved Suspension Reduces Handling!
    Quote Originally Posted by JONNNNOOOOO!!
    cheers sexy
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Quote Originally Posted by vnsmanual View Post
    The cluster "lens" is different from L1/2 clusters to L3 cluster. If you have a broken unit you may need to get a complete cluster for the parts of find some one that has lots of spare parts.
    and 3 Dangerous non ABS VN's
    VN S Manual
    Jul 2009
    no nothing to do with the cluster. the crash pad itself. i have changed the entire dash from a vn one to a vq one.
    now theres a plastic strip about 1.5 inchs wide that runs alonmg the bottom of the windscreen and is connected to the crashpad covering the three main bolts holding the dash in. now i need to know how to remove and insert this strip. cause i need to put one on my vq dash.
    VN S Manual
    Jul 2009
    also ill play round with the speaker grills. they just dont appear to fit thats all. im probably wrong
    VQ Stato & Evo VII.
    May 2006
    Melbourne, North of.
    The panels at the base of the windscreen/top of the dash are held in place by 5 or 6 of those small black screws, you'll need a small screwdriver that will fit between the screw and the windscreen to get them out, it can be quite frustrating!
    88GreenVN's Avatar
    Jun 2006
    Quote Originally Posted by WNTDVT View Post
    Spot on with that. - Almost need to be out of the car looking in the front windo to see the screw.
    VN S Manual
    Jul 2009
    oh really i thought it just un clipped or something. ill try removing my old vn one as practice. thanks for the help, will try tonight and see what happens.
    Might just chuck my vn one on the vq after i dye it. its only a small crack, not really a big deal
  1. What are they called
    By Mossman in forum VY Holden Commodore (2002 - 2004)
    Last Post: 19-12-2010, 07:27 PM
  2. what is this called? And where can i get it?
    By Jamie-b in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-10-2009, 10:33 PM
  3. what are these called, and where do you get them??
    By DANVSUTE in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-09-2008, 10:59 PM
  4. Dog called Sex.
    By ClairBear in forum Jokes/Humour
    Last Post: 07-04-2008, 11:11 AM
  5. Will it even be called VE?
    By ciaranvt in forum VE Holden Commodore (2006 - ?)
    Last Post: 03-04-2006, 08:15 PM
