Results 1 to 11 of 11
Thread: VP calais coolant!!
    Vp calais
    Oct 2009
    Default VP calais coolant!!
    the other coolant compartment off to the left in front of the windshield wiper compartment, is always empty. I fill it up and i check it and its gone!! anyone got ideas, the radiator is fine.
    1992 VP vacationer
    Nov 2009
    Check under the car for drips. My cause was total destruction of nearly all gaskets. Also a year latter my coolant started to go down again but this time it was rad cap.
  3. Default
    1. get it pressure tested
    2. if there's no obvious leak, bleed the system (if there's any air in it it will always force all the coolant out the overflow)
    Quote Originally Posted by zai View Post
    I am not sutpid
    Vr S2 Calais
    Jan 2009
    go over all your radiator hoses and fell them for and crusty material around the hose and check all your hose clamps aswell
    calais_cruzin's Avatar
    calais_cruzin is offline Calais_Rattling....
    92 VP Calais 3.8
    May 2006
    Gold Coast
    check that heater tap, it may look good, but could be leaking, they are very brittle break easy.
    I didnt think mine leaked, but when i went to replace it, the hose lug was broken, but still sorta working
    ________________________________________
    Vp calais
    Oct 2009
    1992 VP vacationer
    Nov 2009
    92 VP Calais 3.8
    May 2006
    Gold Coast
    block up those hoses then, at the tap, take it out block em up, then water dont go in there.
    Or u could change the heater core, but thats a mission
    Vp calais
    Oct 2009
    Warranty Void's Avatar
    Warranty Void is offline Take it apart? Me? No!
    VP Berlina LX V8
    Sep 2009
    The radiator cap is probably the best place to start, if the spring is weakened with age then normal coolant temps will open it and blow the reserve out of the container. Good luck with the heater core, I've heard you can change it without pulling the whole dash if you make some mods to the hard pipes, ie cut them off close to the body of the core and fit heater hose to join up. Maybe someone else knows more about this?
    Warranty Void
    Noy
    Noy is offline
    VN SS 5.0
    Oct 2006
    I had a similar problem when I first bought my car, though I was loosing coolant due to loose hose clamps and the radiator cap was buggered. Like other people have mentioned go over all the hoses/connections with a torch, even better get it pressure tested at your mechanic..
  1. vs 5lt using coolant?
    By Vs_ss_gmtank in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-10-2009, 12:25 AM
  2. Still ****ing out coolant. What could it be?
    By StockoVRWagz in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-12-2008, 07:58 AM
  3. coolant
    By myvq5ltr in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-03-2007, 06:48 AM
  4. VK Calais- Low Coolant Warning?
    By Dan355 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 12-02-2007, 08:39 PM
  5. Which Oil, Coolant Etc Do You Use
    By Gobbles in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-10-2005, 04:23 PM
