Querying About putting Toyota supra running gear into an 89 vn
what engine u runnin?
custom engine and gearbox mounts. custom exhaust, etc.
there was a VR getting round a while ago with a 2j in it from memory.
Engine itsself will fit fine length and height wise. Just lots of fabrication to get it sitting there![]()
would be easiest going with the rb swap...just steal shit from VL and thats virtually it.
vl k frame will fit. maybe easier to adapt.
it will be a bitch to get registered though.
engineering approvals and emissions control aswell as maybe brake upgradees.
I got to have a look at a VR ute with a 2JZ in it. Everything fit nicely in the bay but I don't know which K frame it was running or what the setup was with actually bolting it in. But it was complete and running
1jz or 2jz in a VN-VS is doable, but you run into issues with your steering as the exhaust comes out the wrong side. Generally easier to do an RB conversion, as you can stick with holden parts instead of having to fab up new mounts. Easier to get it engineered that way, too.
and thanks to those suggesting rb swaps but i dont like rbs
mate jam a ecotec in then.
nearly stock parts and newer.
